Recording with playback - Delay issue
I'm fairly sure that this thread has come up before, but I didn't know what keywords to search for and the ones I found were about other delay problems. I'm using Pro Tools 8.0.4 on Windows 7 x64 with an Mbox 2 Mini. This is the first time I record after having to reformat my primary drive, and it's also the first time using version 8.0.4, which is a fresh breath. I just started a new project where I'm using midi to control Superior Drummer 2.2.1 and Structure Free. I started recording guitars the way I've always done it, got through the song... But when I listened to it the guitar was always somewhere around 300ms ahead of the clicks. I've always recorded while having playback with the mix button on my Mbox 2 all the way to the right, muting the track I'm recording, so I hear everything with zero delay. No problems before now. No delay whatsoever during playback, but somethings obviously wrong in the recording process! Here's an image showing what I mean: http://s156.photobucket.com/albums/t...rrent=Help.jpg The red line is showing where the audio should start there. I'm just playing 1/4 all the time here to demonstrate. The grid is set to bars, not samples. Soooo... Am I doing something seriously wrong here? |
Re: Recording with playback - Delay issue
You need 2 things here. First, get the cs2 update. Then, DO NOT work at 48K. This is a known issue with 8.0.4 and the cs2 update solved it EXCEPT for while working at 48K. If you are okay with 44.1(like most of us), then cs2 should make your day
Aha, thanks a bunch! Worked like a charm. Didn't know of the CS2 update. (:
"Playback" Button Delay Issue | capitala | Pro Tools M-Powered (Mac) | 3 | 05-22-2007 09:49 AM |
PlayBack Delay In Vocals When Recording!!Help!!! | Las Philosophy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-03-2007 06:36 AM |
delay before recording issue | phentalmyst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-26-2006 06:35 PM |
Delay in playback while recording | lennyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-22-2005 09:47 PM |
Experiencing a delay on playback when recording a new track | ronmills | Tips & Tricks | 2 | 08-16-2001 05:31 AM |
