Adapter cards by PCI-X PCI-e! Does it work?
Hello everyone,
I hope not to break any rules by posting this post! Who uses Pro Tools HD will know that the PCI-X cards are not compatible with the new Mac Pro Therefore those who want to use your old system HD (with PCI-X cards) or buy Magma chassis or is an upgrade of the cards by PCI-X PCI-e, transactions both pretty expensive. I learned of this "solution" http://www.virtuavia.eu/shop/index.php?t ... I would like to share with you for more information. Basically it is a card adapter pci-x! From a test (not by me) it seems that the adapter is fully functional on a Mac Pro 2 x 3.2 Ghz Quad Core Intel Xeon with 16 GB of Ram 2009 with OS 10.6.4. The adapter in question costs about 200 €. Someone knows something? I am about to buy a Mac Pro, but for budgetary reasons I can not take the new cards pcie pro tools but rather want to orient on older PCI-X cards used. A greeting Luca |
Re: Adapter cards by PCI-X PCI-e! Does it work?
Do you mean this http://www.virtuavia.eu/shop/pci-exp...er-p29855.html ?
I think there may be a problem with it being a Bus Type : − One-lane (1X) PCI Express . It would be interesting for someone in the know to comment on this. |
It looks like you have to remove the metal bracket from the PCI-x card...and then an open space in the adapter's bracket leaves room for the ports. very curious if it works!
Oh, here they say it's cheaper and BETTER than Magma: http://www.virtuavia.eu/shop/index.p...id=29891&sl=EN
Seriously doubt that this will work at all... |
forget it.
--- RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1, MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1 3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate |
--Jeremy |
I emailed virtuavia today (as they didn't answer to phone calls) , asking them if any of their gear could handle 3 Pro Tools PCI cards. I was thinking the ATX 500w tower would be good enough.
They answered very quickly : "Nous acceptons uniquement les cartes PCI 32 bits (pas X ni 64 bits)" translation : "we support only PCI 32 bits cards (no X or 64 bits)". Since I had no further explanation despite I had clearly talked about Pro Tools, I assume it just won't work.
Making sounds and music. Love both. |
I bought virtuavia PCI => PCIE Adapter adapters and against all odds it worked !
http://www.virtuavia.eu/shop/pci-32-...-adapter-.html I am running a mobo with 4 PCIe and 2 old PCI 32 slots but I needed more PCI-e so I bought the adapters and removed the brackets. Both SSL Duende and UAD-1e worked together with my UAD-2 Quad and PT HD2 PCIe for a total of 6 PCIe slots inside the computer itself. sauna-l , the older Pro Tools HD cards is PCI 32 bit specifications but strangely put in a physical PCI-x form factor . Digidesign never made PCI-x cards.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
does this adapter work? | matias4000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2011 06:05 PM |
Will 002 work with g4Port serial adapter in OS9? | JoeM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-08-2010 12:50 AM |
FXpansions VST-RTAS adapter - does it work? | jobijam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-18-2005 09:26 AM |
Does the UAD card w/VST to RTAS adapter work well? | Imagine | Pro Tools TDM Systems (Mac) | 2 | 07-16-2004 07:33 AM |
So does the VST/RTAS adapter work? | medievil | Tips & Tricks | 4 | 02-25-2004 02:45 AM |
