-9073 Error
'Dae can't get audio from the drive(s) fast enough.
Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwidth or CPU load. (-9073)' Anyone know what this is all about? I'm using Macbook Core 2 Duo 2.0Ghz, 4GB, OSX 10.5 .6 Firewire Audio Drive Mbox 1 PT 8.0 All Defragged. |
Re: -9073 Error
How many tracks?
Are you using any plugins that stream audio, like BFD?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: -9073 Error
I'm using the 'best' Pro Tools' system that I have owned since I started on PT5.1, Audiomedia III on a G4 450mhz years ago
and now I have the least functioning machine that I have ever had...... I have had these 4 errors continually: -6105, -9136, -9073, -9512 Have done all the usual things: delete prefs, reboot, defrag, chang ports, update plugs etc. Have tried both Mbox 1 and Mbox 2 with the same problem. I can't play for longer that 4 seconds before audio drops out with an error message. Using 9 tracks 4 plug-ins: Digi Eq, PSP Easy Verb, Massey CT4 and Ozone 4 on the Master On PT8 cs3, OSX 10.5.6, Macbook 2.0Ghz, 4GB, 7200 Firewire Audio External drive, Mbox 1 & have tried Mbox 2 Any Ideas?? Cheers (I'm just about to re-format my Audio Drive, and see if thst makes a difference) RE: No difference after formatting Audio Drive Only option is to go back to 7.4LE - No one has offered any solutions here at the DUC. PT8 is a nightmare - it's not for musicians, it's for computer techs. |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error 9073 | djobar | Storage Subsystems | 0 | 12-06-2007 08:06 AM |
-9073 error | darrylectomy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-28-2007 07:25 PM |
error -9073 | standish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2007 05:33 PM |
adat loopback error#4 and error 9073 | uri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-22-2003 11:19 AM |
