Setting up Digi 002 to External Clock source?????
I recently was given an older Lucid Genx6 from the studio I work at.
Knowing the 002 doesn't have a word clock input, I bought at BNC to S/DIF adapter. I'm running the Lucid at superclock and taking its BNC out to my Digi 002's S/PDIF input. When I try to set my clock source in the Hardware menu to "S/PDIF" it says "Your External Clock Source is Invalid. Reverting to Internal". What's going on here? Can someone help me out? |
Re: Setting up Digi 002 to External Clock source?????
yeah...you're right... I did just buy a BNC to RCA adapter, wasn't really thinking on that one I guess. And they only make BNC to XLR and AES impedence adapters, but if that was the case I would have to search for adapters to those. By the time I go through these adapters the clock isn't going to be worth anything. Im screwed.
Any other ideas??? |
Just an idea. You mentioned that you was running the unit at superclock (x256), not word clock. The 002 cannot clock to superclock. That was for Mix systems.
Tom |
I thought since S/PDIF carried L mono R mono and clock along the cable it might work. But I do suppose that would just be wordclock and not superclock. So, yeah... Tom just gave me the answer I needed, it just doesn't work. I suppose I'll just use the lucid for outboard gear, since I don't think I'll be buying an HD or old mix system anytime soon... or ever.
And there's no AES output on the LUCID, so no luck with that Chief. |
Setting clock source for 11R | Legion6789 | Eleven Rack | 6 | 12-04-2011 06:17 PM |
PT 8.0.4 is re-setting my clock source.... | JayStyles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-23-2010 06:54 AM |
External Clock Source for Digi 002 | alejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-14-2005 11:14 AM |
External Clock Source 002 | foisyt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-12-2005 09:54 AM |
IS EXTERNAL CLOCK SOURCE WORKING? | Pete Weaver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-26-2002 10:20 AM |
