Old 12-12-2023, 11:33 AM
zeeman zeeman is offline
Default Right Click Marker Crashes 2023.12
Hey Folks,
Everytime I right click a marker to edit the marker parameters, PT crashes. either an instant crash or spinning wheel. Trashed prefs before install. after 5min of troubleshooting to get more info, if that new little box in the upper left corner is highlighted,PT crashes. if i un-highlight it. PT does not crash. Im not even sure what that box is yet:)but i can make it happen every time.
Easy fix, just don't highlight the little box in the upper left
Everything else is cool so far.just opened a bunch of sessions.
Chris z
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 12-12-2023, 11:39 AM
Default Re: Right Click Marker Crashes 2023.12
Yikes, I see what that little box does. if it's not highlighted i cant jump from marker to marker. So it seems if i wanna edit a marker, un-highlight, then highlight if i wanna jump from marker to marker.
Can anybody else confirm this behavior.
Simple work around. and hopefully just my system right now.
will confirm later if this happens on my second system.
thx
Chris z
MAC OS 13.6.1
PT 2023.12
Old 12-12-2023, 12:59 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Right clicking markers does nothing for me. No crashes.
I've always double clicked markers to modify its options and settings.
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 12-12-2023, 01:10 PM
Hey nednednerb.
Thx for clarifying this. i always right clicked and your right, its not happening if i just double click. so double click it is for me now.
thx
z
MAC OS 13.6.1
PT 2023.12
Old 12-12-2023, 07:51 PM
skylar_battles skylar_battles is offline
Right click does nothing, but maybe this behavior has been changing in the past year. No crash though.
Command click or double click to edit a marker.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 12-12-2023, 08:13 PM
tope d's Avatar
tope d tope d is offline
I wasnt able to reproduce this. Have you already tried deleting your prefs?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 12-13-2023, 04:37 AM
Hey Tope,
So after more trouble shooting, the PT crash only happens if there is a window config associated with the Marker.
I use 4 window configs that are set to markers 1-4 so I can immediately change all my windows depending on what set of windows I need open.
Unless Im wrong, in every other version of PT when I add a new track, I then need to update my 4 markers so that the new track is included in the window config. I do that by right clicking the marker and click OK. I have to do that for each marker or the new track is not included in the window config. If I right click a marker that has a window config associated with it, PT crashes. Every time.
Thanks in advance for any help.
Chris z
MAC OS 13.6.1
PT 2023.12
Marker behavior broken in 2023.6 Kevin Nettleingham Pro Tools 25 03-30-2024 09:32 AM
marker update bug in 2023.9 filmnoise Pro Tools 0 09-21-2023 06:46 PM
2023.6 Bug: 'None' Marker color is not saved orchetect Pro Tools 4 06-29-2023 09:41 AM
Insert Marker Slot broken in 2023.6 off the wall Pro Tools 7 06-09-2023 09:17 PM
2023.6 keyboard shortcut for Track marker Macsearcher Pro Tools 1 06-09-2023 05:52 AM
