Old 09-10-2021, 03:06 AM
rickmaymi rickmaymi is offline
Default Re: Click on a session, nothing happens...
Hi!
Thanks for the info. Yah, I have time machine, I re-uploaded the old protools. that didn't help. Not sure how to recall the state of the entire computer
Old 09-10-2021, 03:55 AM
Ben Jenssen's Avatar
Originally Posted by rickmaymi View Post
Hi!
That's a pity. Neither do I, because I stopped using Time Machine several years ago, mainly because, at least back then, it could not be trusted to restore a startup disk properly. I use Carbon Copy Cloner.
Anyway, I feel pretty confident that what has happened is what I described; PT cannot find some sessions because where they used to be, there is now a "link" to where it is in iCloud.
When you manually tried to copy things from the icloud Drive, are you shure you placed them exactly where they used to be?
Did you check if the "Optimize storage" option was on or not? I suggest you do NOT change it's status now, as I described if you do that, things start to happen. Let's wait a little and see if someone else has any advice.
Jeffro, if he manually restores /Users/*name*/Documents/Pro Tools/Project Cache would that do it?
The fundamental problem, I think, is I'm not shure how iCloud handles pushing back and forth the folders when there has been a manual copying, of the Documents folder f.ex.
Discovery: Right-click session name daeron80 macOS 1 03-30-2012 11:53 AM
I tried searching?, session without a click basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-07-2010 10:21 AM
Double Click session file will open PT, but not session Hearfilm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2008 08:38 AM
How to get Click value diff. than session Chris Coleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-12-2004 03:38 PM
Need my Click track to start later than my Session louis King Tips & Tricks 0 04-28-2000 07:38 AM
