recording guitar directly into 96io?
can i plug a guitar directly into the 96io or do i need to go into my preamp first?
Re: recording guitar directly into 96io?
Chris
so what can i do if i dont want to go thru the pre? DI box?
Yeah DI should work, make sure it says balanced out and that should get u to line level.
Of course xlr to 1/4" TRS cable I suppose it could be 1/4" TRS to 1/4" TRS also if your DI box will let you do that
so if not my pre amp and not a DI box what then? kinda funky they make a "pro" interface without mic or direct inputs...
Many preamps are equipped with hi-z inputs, which is what you need. Why don't you want to use a DI and/or a preamp?
i suppose i will use my avalon i just really prefer to record everything dry except vocals... are there direct input to line output units? i really luv pro tools and digidesign products but i just dont get why they would make the HD interface without inputs that u could atleast switch from line to direct level
You can't get much "drier" than a DI box or, for that matter, a good transparent mic pre. It's been like that since the beginning of recording audio time. Tape machines certainly never had line inputs for guitar.
all the DI boxes i have seen output at mic level thats my problem with DI box... and my avalon is awesome but definantly not transparent... i know there has to be something passive that converts direct input into line out...i did read in my 96io manual that it accepts balanced and unbalanced signal?? that doesnt mean it would accept a direct input??
You will be able to record your guitar that way, but don't do it, your sound will suffer. Get a good mic preamp with a DI input, Avalon has the M5 and the U5, I use the Universal Audio 6176 for recording DI, it is really good.
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave |
Recording Directly to Macbook Pro | ionStorm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-04-2011 06:58 PM |
Can't record guitar directly plugged to 003 Factory | Ombor10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-28-2010 04:19 AM |
96io activate spdif recording? | buckaroo | Pro Tools TDM Systems (Mac) | 5 | 02-27-2009 10:16 AM |
Recording Bass Guitar directly into Digi 002? | pribb1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-03-2004 06:25 AM |
recording guitar directly to 001???? | remains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-28-2002 09:18 AM |
