#21
Re: 003r monitor section
[QUOTE=netnoggin;1593218]Might be a typo, so before it goes further - did you mean to say you imported a track at 24/48 instead of 24/44.1?
/QUOTE] Sorry, forgot to answer this..No I meant 24/44.1 |
#22
-Converters are mid to crap level (96 io is mid to crap level, 192io is mid level) -Clock for Mbox, 002, 003... is not good (the same for 96io, a little bit better for 192io) -Sample rate conversion is not top end (the same is for HD) -Monitor controller is not good (my 003rack exibit 0.9 dB difference between L and R at max volume) So for all for the above things I agree with madarchitect: PTLE has some flaw BUT Jitter means nothing with bounced track or printed tracks. The jitter is a clock incosistency and affect A/D and D/A, you can hear jitter but it absolutely don't modify the data inside a DAW. So external summing is affected by jitter, monitoring is affected by jitter but not bouncing or printing tracks. And again I don't understand what does "PTLE is not sample accurate" means. PTHD suffer for the same problems of clocking and jitter, a little bit less with 192 io, but this doesn't influence the track printing or bouncing. You can always use a better clock, or converters as you can do for say 003 (as I do). PTHD suffer the same phase distortion when inserting processing that alter signal above nyquist. So I don't understand the differences between HD and LE in terms of "SAMPLE ACCURATENESS" This is not a LE vs HD, I want only to understand why somebody state PTLE isn't sample accurate, and what this means. P.S. I mean printing track: recording audio tracks to another audio track through a bus. I mean bouncing ...beh you know what I mean. |
#23
But the proof is in what you hear..forget the technical jargon..if u can hear a difference, that means that there IS a difference..mixing skills, room acoustics and monitors aside...if a print doesn't sound good in the same room..u jsut eliminated the monitoring chain..guess what it has to be.... |
#24
I prefer to say thank you for your time, I really appreciated your explanation of what you thinks. I just say for that I know about digital electronic architecture I don't think so |
#25
You are correct. I didn't mean to indicate that by including my statement in the same post with the other stuff. It was actually Brad that brought up the difference between the two. But you did indicate the 003R was a "hobbyist" piece of hardware, which kind of caught my eye. While I'm well aware of the differences in hardware specifiations and even the specs of the chips contained in most of them, I don't know if we can really say what "professional-level" hardware is anymore. People are making a living doing amazing things with LE hardware, including music that is sold to end users for a profit. That does fit the textbook definition of professional. Not to mention many a recording has gone gold being born from much more humble beginnings than an 003R.
#26
While this may all be true, one of the most difficult things for any studio is to make mixes that sound AS good in the real world as they do in the studio. Before you start knocking digi, AGAIN, it sounds to me this is the studio's fault and they need to do some tweaking! Come on guys...
www.rickqueststudio.com |
#27
You're right, we're off the OP's beaten path considerably. As I said, the music is what matters. The monitor section of the 003R does have it's limits, but I've never used it much. I always come out of the direct outputs. You lose a little functionality that you paid for (mute, level control, etc.), but if you want a cleaner signal, less things in the chain is always a better bet. If you really need the functionality, getting a Presonus unit or one of the Dangerous Music units will restore it and then some. As for the other problem: Quote:
So I would start out by picking your personal reference mixes. It doesn't matter what they are; it's whatever works for you. But they should be recordings that you know translate well to many types of end devices, from studio monitors to iPods to PC speakers to your car to the neighbor's cheap stereo - you get the idea. I have a handful that span different genres. One example - Lately I kinda like Garth Brooks' "Long Neck Bottle" for C&W. To each his own. Once you have your trusted references, use your ears (and eyes) to compare your material against the reference and try to deduce what's different. Listen closely. Listen through the mix and pick out individual instruments and try to determine why the reference material works so well. This is part of that critical listening ability that you really must have to do decent mixes. And if you struggle with it at first, don't fret. Critical listening is just like a muscle - if you exercise it, you will find it develops over time. But you must accept one fact of life - if you don't have any success at developing this skill, you are better served by putting your gear on Ebay. The key point to reference mixes is no monitoring system and acoustic environment is perfect. More important than attaining perfection is understanding the anomalies and limitations of your recording environment so you can adapt to them. If you don't understand how those things affect your listening, you will invariably make counterproductive adjustments to your material to compensate. A classic example is turning up the bottom end on mixes to unwittingly compensate for either lack of frequency response of the monitors or maybe the low end of your studio is being sucked up by room modes or wall-bounce phase cancellation at the mixing position. But the result is the same - things may sound good in the studio, but muddy or boomy when played on anything else, because you overcompensated. This does not mean you can't make good mixes in this room with this equipment. It just means you have to understand it happens, and mix accordingly. Leave the bottom a little lower in the studio, and it will come out right on the other gear. Again, the key is knowing your environment. Back to the reference material - if you have the above situation, your reference stuff probably sounds a little lacking in the bottom end when played in this studio environment. Part of my recording and mixing regimen is to regularly listen to test mixes on other speakers and in different environments (and different volume levels - extremely quiet, extremely loud, etc.) as I go. I even have a small FM transmitter wired into my signal chain, so I can step out to the car and listen with ease. It never ceases to amaze me the needed adjustments I pick up on while revving the engine. Things have a different perspective with a S/N ratio of something less than 5 because of wind and engine noise. I hope this give you some ideas. What it really comes down to is the gear is important, but not the magic bullet. Your ears are the magic bullet. I would venture to say while it may technically be deficient in some ways, your 003R monitoring section is not what will make or break your recordings. A parting thought: "George Martin, producer for The Beatles, actually believed that the limitations of the four-track stimulated creativity and that the 1967 album Sgt Pepper’s Lonely Hearts Club band would not have been as good if recorded on a 24-track." http://blog.amatistudios.co.uk/2010/...mid-1960s.html |
Monitor Section | Hanswurstlsepp | Avid S4/S6 | 36 | 06-06-2014 02:52 PM |
003R & C|8...C|8 Monitor section not working... | Idahoguide | ProControl, Control|24, Command|8 | 1 | 02-22-2008 05:01 PM |
003R & C|8...C|8 Monitor section not working... | Idahoguide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-20-2008 12:21 PM |
C24 Monitor Section | s0nguy | ICON & C|24 | 6 | 08-10-2004 07:48 AM |
C-24 Monitor section | Rollerex | ICON & C|24 | 30 | 09-18-2001 10:18 AM |
