Upgrade Mbox 3 Mini D/A for cheap
I'm mixing ITB using ProTools and the Mbox 3 Mini. (I don't do any tracking and I have no outboard gear.)
What do you guys think would be the least expensive upgrade to get a better D/A? The obvious choices would be the Forte or Duet 2. Since I don't like running Apogee's software, I'd opt for the Forte. Do you think it's worth dropping a $400-$500 just to hope that I getting better monitoring via the Forte's D/A? I'd eventually like to get a UA Apollo, but it may be awhile until I have the funds. Another options would be to look for a used Mbox 3 Pro. However, it would be overkill having all that I/O. Opinions? |
I am just going to guess the answer here might be don't worry about the interface and worry more about monitors, but let's see....
What type of audio work are you doing? What is the problem/limitation of what you have now? What exact monitors and/or headphones are you driving now? Is it perceived audio quality or number of outputs (what monitors do you want to use with the new system? multi-channel needs or integrated monitor management features you want? |
Re: Upgrade Mbox 3 Mini D/A for cheap
Thanks for the reply!
As mentioned I am doing mixing (pop/rock). I don't need any more I/O channels. What I am interested in is improving the quality of my D/A. I mix on NS10's and a sub going thru a SPL monitor controller. My weakest link now is the MBox 3 Mini's D/A. Just wondering if the Forte would be any improvement. I would like any incremental improvement before I invest in an Apollo, etc/ |
Any of the units you're talking about are going to be very small improvements if at all. You would be better off spending the money to upgrade your monitors. You might also consider spending some money on acoustic treatment, if you don't have that already. That will also make more difference than going to any of those other interfaces.
That's two votes...
Thanks for the feedback. I'll take your advice and save my money. I have already invested quite a bit in room treatment.
I'm getting amazing mixes on this Mbox Mini ... better than my HD3 mixes. I guess a noticeable upgrade would be to something like UA Apollo + a summing unit. |
I think an upgrade to an Apollo will be not as noticeable of an upgrade as you might expect in terms of D/A.
Going to the HD interfaces with an HD Native system, that will be an upgrade. @Darryl, It sounds like he mainly does mixing and not tracking, so all the preamps, mics, etc. may not be an issue for him. In his situation, perhaps a summing box might be good, but of course he'll need an interface with enough outputs to make it worthwhile. |
Mbox Mini PT 9 upgrade to 11 | matt1801 | Pro Tools 11 | 6 | 05-15-2013 07:57 AM |
Looking to upgrade from mbox mini | soundmind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-05-2011 01:34 PM |
looking to upgrade from mbox mini | tony.tipton | Pro Tools M-Powered (Win) | 0 | 11-28-2010 07:57 PM |
Does owning *any* mbox allow one a cheap upgrade to PT 9? | Ru_C | Pro Tools 9 | 3 | 11-11-2010 05:46 AM |
003r+ and mbox 2 mini upgrade PT9 | joakim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-06-2010 07:02 AM |
