Bug in 2023.12, Last Memory Marker Moving When Copying to End
hello everyone, so instead of trying to explain, this
i created. a short video on it, yes my audio is on left side only, that's another issue, lol on my previous version, 2022.9.,, this did not happen, not sure if because i'm on Sonoma, if anyone can verify on Ventura, or Monterey. running 2023.12 https://www.dropbox.com/scl/fi/t6bus...ge3gznad5&dl=0 Last edited by musiclee; 01-08-2024 at 02:20 PM. |
Re: Bug in 2023.12, Last Memory Marker Moving When Copying to End
of course i know the workaround, is to place cursor ahead a bit, and then select all tracks again, and then paste, etc,
too many extra steps |
Since you're copying a blank space from the start of your selection and pasting it over the END marker, it's replacing the blank marker space. This would happen for any marker. For the record, this also happens in 2023.6.
thanks, but i know for a fact. this did not happen in 2022.9,
i do this all day, every day, 100x times a day, and yes, i copy. space @ beginning, so that my "segments". are not bunched up... it should not shift that end marker, i am not pasting it over the marker, i am pasting @ end, it never did, in all versions of pro tools, and i've used them all, version, 9, 10, 11, 12, Studio, etc Last edited by musiclee; 01-08-2024 at 02:21 PM. |
thx its2loud, for your reply though,
i will try this same thing on 2022.9. as i still have that installed on mac as well, and report back. Last edited by musiclee; 01-08-2024 at 02:21 PM. |
so here is a link to a short VIDEO using the SAME session, same exact process,
using PT Version 2022.9 https://www.dropbox.com/scl/fi/hdbiu...ge89njj7y&dl=0 i know a bug when i see one, as i've done this thousands of times, every day, every year. Last edited by musiclee; 01-08-2024 at 02:23 PM. |
Avid. Marianna
Can you report , and fix for next update ? |
Since you're doing this in shuffle mode it looks like expected behaviour in 2023.12 but like bug in 2022.9
that's great, hope my 2 videos help in "fixing" this
sometimes it's easier to show it, then to write it, also, that other "bug". where you can only click that 1st box to select memory markers, when clicking then holding shift. for a selection, we used to be able to click anywhere, on name. etc. if you'd like. i can do a video on that too. lol |
Marker behavior broken in 2023.6 | Kevin Nettleingham | Pro Tools | 25 | 03-30-2024 09:32 AM |
Right Click Marker Crashes 2023.12 | zeeman | Pro Tools | 6 | 12-13-2023 04:37 AM |
marker update bug in 2023.9 | filmnoise | Pro Tools | 0 | 09-21-2023 06:46 PM |
2023.6 Bug: 'None' Marker color is not saved | orchetect | Pro Tools | 4 | 06-29-2023 09:41 AM |
Insert Marker Slot broken in 2023.6 | off the wall | Pro Tools | 7 | 06-09-2023 09:17 PM |
