Fabfilter ProQ-3 noise??
I keep ProQ 3 open on a third screen so I can glance at the RTA function once in a while and noticed some kind of "noise" showing, so I went looking for a cause. While I don't hear anything, bypassing this plugin makes the reading go away(see screen shots). I can bypass every other plugin in the session with no change. I can also remove the HP filter with no change. Note that the screen shots are happening with transport stopped and no audio in the session. Any ideas?
Re: Fabfilter ProQ-3 noise??
Bypassing the Q3 plugin also makes it stop analyzing the input. So of course it goes away. But it means nothing.
So your test isn't telling you anything. (you have noise feeding that channel from its input or a modelling plugin somewhere upstream)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Correct. Double check you don’t have any hidden tracks with plugins instantiated and check you don’t have an Aux channel with an input assigned to your I/O. Something is creating that noise (which is quite high and has to be audible if you turn up your monitoring) and it’s DEFINITELY not ProQ3. Sent from my iPhone using Tapatalk |
There are plugins on the market emulating analogue gear including the noise the original gear made. You would see this on an anlyzer like this while transport is stopped. Also there plugins like Audioease Speakerphone which can be set to be muted on stop.
That makes sense(though I wish it kept analyzing). Digging deeper revealed 2 interesting things:
#1-In typical Waves fashion, H-Delay had "Analog" defaulting to on(which caused the high freq reading) #2-Waves Puigtech EQ-1A causes the ProQ meters to register signal around -84, but does not show a noise component. This plugin doesn't have the usual "Analog" control, but instead it has a Mains knob with options of 60Hz, 50Hz and off. Setting to off cleans that up. Both plugins are now set to default with this stupid feature turned off. Thanks for direction
Yes those Waves plugins default to producing noise, it's really stupid. There are some other devs that do it but it should always be an option.
We spent the entire history of recorded sound trying to get rid of noise but for some reason they think that's what we like about vintage gear
~Will |
Beam of white noise in one hand, input and output knobs in the other!
I'm ready for a Loudness War! It's not over yet is it? Noise... everywhere... When the prevailing wisdom is now saying "let your recording gain go down, don't force yourself to max out your use of headroom", putting this kind of extra noise at low level in an industry where things are still going for now to be boosted to a high LUFS by delivery, its a recipe for listener fatigue and masking.... Weird thing to do, indeed.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Sidechain Delay Compensation causes noise to be generated from Fabfilter Plugins | cunninghamaudio | Pro Tools | 0 | 08-24-2022 12:07 PM |
WTB: Fabfilter Pro-MB | TrentWilliams | Buy & Sell | 0 | 09-08-2018 01:30 AM |
FS: FABFILTER Pro-DS and PRO-MB | senghor | Buy & Sell | 4 | 08-01-2017 04:36 PM |
WTB: FabFilter ProQ 2 | Becharax | Buy & Sell | 0 | 06-19-2015 06:44 AM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
