Klangfreund LUFSMeter - not a valid 64 bit aax plugin
Purchased the Klangfreund LUFSMeter tonight and get the following error message on booting Pro Tools after installing:
"The following plug-ins failed to load because they are not valid 64 bit AAX plug-ins: LUFSMeter.aaxplugin" So far I've tried: -re-installing the plugin overtop the original installation -un-installing and re-installing -trashing pro tools preferences -restarting the computer -installing another plugin and then re-installing LUFSMeter (as previously I was having this issue with TBPro Audio's dpMeterII until I installed LUFSMeter, at which point this problem switched from dpMeterII to LUFSMeter) I saw threads about the same issue regarding UAD and Waves plugins, but nothing regarding Klangfreund or TBProAudio plugins. Klangfreund doesn't have a License Manager like Waves does or a Control Panel like UAD does to tackle the issue in the ways suggested in those threads. Waiting to hear back from their support but it's the weekend and not expecting to hear back until Monday. Reallllly hoping to have this resolved before then as I've got work to do this weekend and could really use this meter. |
Re: Klangfreund LUFSMeter - not a valid 64 bit aax plugin
Same problem. It won't load in PT 10 and gives the "LUFSMeter - not a valid 64 bit aax plugin" in PT 12.
If you hear back, please post their reply here. If you're in a real pinch, Melda's Loudness meter measures LUFS, but is uses the older, ungated standard. Still, if your mix has no gaps of silence it should get you a good measurement. https://www.meldaproduction.com/MLoudnessAnalyzer Good luck!
_________________________________ Adjunct Faculty: Columbia College Teaching: Audio for Visual Media & Post Production Audio _________________________________ Personal Audio Site: JennAudio |
I downloaded a slightly older version of the plugin from their server by editing the current download link and changing the version number to 1.4.0
It loads and works properly. You can see the differences in the versions here: https://www.klangfreund.com/lufsmeter/releasenotes/
I'm the creator of the LUFS Meter. To fix this, use the latest (not yet linked on the website) LUFS Meter 1.4.3. For customers: https://www.klangfreund.com/download..._Installer.dmg Demo version: https://www.klangfreund.com/download..._Installer.dmg The AAX version 1.4.2 of the LUFS Meter is only working in OS X 10.11.x. In earlier versions of OS X a "not a valid 64 bit AAX plugin" message is raised. This is caused by an issue in the signing tool that needs to be used in order to create a valid AAX plugin. Some plugins by other companies created recently are also affected by this. As a user there is no workaround to make such a plugin work. All you can do is contact the plugin developer and request that he creates a new version with the latest signing tool (v3.0.2 or later). Version 1.4.3 of the LUFS Meter has been reported to work again on pre El Capitan versions of OS X. After some final tests by me it will officially replace version 1.4.2 on the website. Before this incident I tested each release of the LUFS Meter in Pro Tools 12 under OS X 10.11 (64bit) and in Pro Tools 10 under OS X 10.6 (32bit) and expected it would then also work in PT with an OS X version in between. Now I have extended the testing to more versions of OS X. Btw: If you need a quick reply from me, please use https://www.klangfreund.com/contact/. Kind regards, Samuel |
how do i get a valid code?? | guyfromthewoods | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2008 08:33 PM |
not a valid record drive on new g5,- valid on pb?! | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-20-2006 09:01 AM |
PT 7 Plus Upgrade still valid? | SeasonOfPain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-23-2006 06:17 PM |
G4 rebate valid for UK too? | Renie | Pro Tools TDM Systems (Mac) | 0 | 05-17-2002 04:58 PM |
Comparing a mix to CD valid? | village1 | Tips & Tricks | 6 | 01-13-2001 12:36 AM |
