Old 11-04-2011, 10:46 PM
pinnacle pinnacle is offline
Default transfuser loop pop
In transfuser when I record a loop there is often an pop at the end. How do I stop this?
Old 11-08-2011, 01:28 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: transfuser loop pop
Crackling and popping is often a sign of a clock problem. Impossible to know without any knowledge of what equipment you're using though.
Does the pop happen only on a recorded track using transfuser or does it happen on other tracks as well?
You say " there is often an pop at the end." By that, am I assuming correctly that the pop is not always there?
Before recording a loop, are you making your selection in the timeline using 'Grid' mode? If not you may be capturing a fraction of the sound of the next beat at the end of the loop.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
Loop checking - can Transfuser do this, if not - ideas? Farmer Dave Virtual Instruments 14 01-02-2011 11:39 PM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 03:14 AM
