"recording" or making a "tempo track" using tap tempo
Hi guys,
is it possible to create an ever changing tempo track by continuesly tapping the tempo (pressing "T") and let protools "record" a tempo track out of that ? or does tap tempo good only for applying a certain tempo for the whole project. i know i can enter a tempo change manually but its a 3 houre long project and was not played to a click and is ever changing. I am open for suggestions ...
2009 8 core mac pro "nehalem" with 6GB ram, 002R, command 8, pt 10.3.5 |
Re: "recording" or making a "tempo track" using tap tempo
No but that sort of functionality would be most welcomed.
Aaron Mulqueen - 001 HD Native |
Tap on a MIDI controller to record MIDI notes while your session plays. Then, use Beat Detective on the MIDI notes to generate Bar/Beat Markers.
If there aren't any responses here, I'll post this question in the more appropriate forum location. Thanks! |
Eleven Rack standalone Editor: Can it "lock hardware tempo to session tempo"? | ToddnTodd | Eleven Rack | 17 | 02-02-2014 02:29 AM |
Can you "Perform" a tempo track? | Tim R. | macOS | 6 | 11-14-2013 11:40 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
