Old 07-31-2022, 08:33 AM
easyrider easyrider is offline
Default Can't Hear Hardware insert- Please Help! IO Pics and Video inside
Please read this first
https://forums.presonus.com/viewtopi...286512#p286512
I have done what that guy had said have said and I have signal going to the SPX 990 Hardware and returning to Input 7/8 on the Quantum.
See Video here
https://youtu.be/vFDgo48b_pA
But I can't hear anything and nothing is coming out of the Main outs when I select the insert.
Have I missed something?
I'm new to pro tools so i maybe missing something obvious?
Tech:Quantum and ASP880 / Yamaha MT120S / Ryzen 5950X /Win 11 Pro 64-bit /Pro Tools 2023.12/ Shure DMK57-52 /Neumann TLM 102/ Oktava MK-012
Mic Pre's Focusrite ISA One/ DAV Electronics BG1/ Joe Meek VC3
Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/
Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R
Old 07-31-2022, 08:44 AM
Emi's Avatar
Emi Emi is offline
Default Re: Can't Hear Hardware insert- Please Help! IO Pics and Video inside
I´d say double check the patching (hardware patching)...the cables that go from the spx to the interface...
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 07-31-2022, 09:03 AM
I have checked that I'm getting signal but no sound see video
Old 07-31-2022, 10:06 AM
Emi's Avatar
Emi Emi is offline
Yeah, I see it. Try to default everything in I/O menu, maybe there´s a wrong named path....
Old 07-31-2022, 10:16 AM
Emi's Avatar
Emi Emi is offline
I think I spot it. Try patching this:
So presonus ouptuts 5/6 - SPX990 - presonus inputs 7/8
Old 07-31-2022, 10:40 AM
yeah its patched like that...I get signal to the hardware FX and back but I get nothing on the main outs when the Insert is engaged.
When I disable the insert I get sound on the main outs.
Old 07-31-2022, 11:19 AM
Emi's Avatar
Emi Emi is offline
Have your tried 7/8 on both presonus ins and outs?.
This is my last shot and I´ll let other to chime in, I promise
Old 07-31-2022, 01:18 PM
Yes.
I fired up studio one and got everything connected and working.
So I know its not
Hardware
Cables
Its something in protools im missing
Old 07-31-2022, 02:08 PM
if this is your first time using inserts in Pro Tools. Start with an empty test session, maybe default all the IO as well, and get a mono insert with a straight through cable to work. verify its working by unplugging the cable.
your videos is not a help, waving a camera/phone around at stuff that nobody can read what is going on on the screen is a waste of time.
what exactly are all the cable connections you have between boxes, nobody here wants to wade through multiple forums to work out what you are doing. say it clearly once. that it works in another DAW not all that helpful... most other DAWs do not have the IO output/input matching requirement of Pro Tools.
what exactly is the playback engine set to? you using aggregate IO? -- don't do that.
you got low latency monitoring engaged? -- don't do that.
but yet again with folks struggling to get started with hardware inserts... you are really doing all this to get a crappy old Yamaha SPX 990 running as an insert when everything it can do is done much better by modern plugins. I hope it has some particular crappy retro effect you specifically are after. Is all this hassle worth it?
Old 07-31-2022, 03:59 PM
I defaulted all the IO
I have setup an insert in Studio one and Cubase 12 without issue.
OK thanks for the feedback. I was just asking why it takes a rocket scientist to setup an insert in pro tools when I did it in minutes with Studio One and Cubase 12.
what i have in the IO screen shots
Regardless of the ****ty SPX 990 I have is irrelevant...I want to use other hardware I have aswell...So the SPX 990 is meaningless in this usage case....As I could be using a 1176 on the same IO and it still doesnt work.
clip gain "wave" symbol. what is it? pics inside musicmixer04 Pro Tools 12 2 09-16-2017 03:40 PM
How to Insert Pics into Your Post Barry Johns General Discussion 6 01-26-2015 10:31 AM
Should I get rid of my SE Reflexion Filter? Booth plan PICS inside! DJ Hellfire Tips & Tricks 11 01-04-2011 08:06 PM
$1000 i7 920 build complete and successful. PICS inside. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-16-2010 12:21 AM
Can't hear midi playback inside PT 6.4 Ditherman23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-22-2005 10:48 AM
