Old 03-29-2012, 09:24 PM
World Spirit World Spirit is offline
Default Why is the limiter not limiting?
I'm simply trying to prevent any spikes in volume to prevent both unwanted volume levels and unwanted feedback/distortion. The limiter used in PT as an insert doesn't seem to do anything at all. I thought that it would act as a volume attenuator so I could just select a db level that I don't want to exceed (and thus compress with this insert). Help!
Old 03-30-2012, 09:34 AM
daeron80 daeron80 is offline
Default Re: Why is the limiter not limiting?
Feedback? So this is in a live-sound situation?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 03-30-2012, 10:29 AM
travgei travgei is offline
Are you talking about the Maxim limiter in pro tools. I have had it clip before, if there is any clipping in the channels that are going to the master.
Old 03-30-2012, 05:46 PM
For recording and live.
The main thing: Preventing clipping & digital feedback during louder portions of a track by attenuating or limiting the increase in db.
I'm actually trying both the Compressor/LimiterDyn3 and the Maxim insert.
There is clipping on all of my tracks, including the Master.
Old 03-30-2012, 06:13 PM
Dism Dism is offline
Neither of those plugs are very effective at limiting, to be honest. Of course, neither are brick wall limiters.
However, I would start by bringing down the gain so peaks hit yellow at highest, and then use plugins and faders to bring up the levels. Then you can tweak until you're satisfied with the volume, and compress far less than you have to.
If you're already clipping on the way in, there's not much a plugin is going to do to help.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-30-2012, 07:16 PM
CME CME is offline
Default
What is your chain? If you're to use pro tools live you'll need a pretty powerful computer so you can reduce latency as much as possible.
Unless you have low latency monitoring enabled, but that bypasses any inserts and would be why your plugs aren't working. LLM bypasses any plugs.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 03-30-2012, 09:26 PM
LLM is not selected. I'm not sure what is meant by the question on the chain. Are you asking for the entire physical gear arrangement?
Old 03-31-2012, 03:02 AM
Greg Malcangi Greg Malcangi is offline
Sounds like you are recording too hot, mixing too hot and/or have the threshold too high on the limiters.
G
Old 03-31-2012, 06:33 AM
CME CME is offline
Default
Yeah how is pt integrated into the system? Maybe patching in somewhere else can help.
Old 03-31-2012, 04:34 PM
Two interfaces (11Rack and Saffire 40) used as a PT Aggregate I/O. That's all the gear I have connected. I use an iMac with the latest OS version and updates. The latest PT version too.
soft-limiter on mbox 3 soft-limiter.. overdriven tape saturation sound mjhann83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-07-2011 09:01 AM
LImiter on audiotrack Vs Limiter on auxiliar track cinetj General Discussion 2 07-15-2008 11:15 AM
question about EQ and limiting mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-15-2007 08:26 AM
Oxford Limiter vs TC brickwall limiter stargazer Pro Tools TDM Systems (Mac) 3 04-28-2006 12:32 PM
Waves L1 limiter vs. Focusrite D3 limiter??? Danny Caccavo Pro Tools TDM Systems (Mac) 1 05-01-2000 12:14 AM
