Old 09-03-2006, 05:15 PM
madlove madlove is offline
Default Automation Trouble - Help Please?
Hi:
Im trying to automate a plugin effect, for example, the Master Bypass for the SansAmp. Even though the automation points showup correctly in the waveform, the effect is not responding correctly. It will come on but won't turn off, or be on all the time, crazy stuff like that. I can monitor it fine, but even thing goes haywire on playback. Anyone have any suggestions on why this would be happening? Hope to hear back, thanks, Chris
Old 09-04-2006, 01:16 PM
Default Re: Automation Trouble - Help Please?
*Bump
Old 09-05-2006, 01:20 AM
steppenwolf68 steppenwolf68 is offline
is this only happening with Sansamp ? If so, maybe it's a bug and you should contact sansamp
Old 09-05-2006, 07:51 AM
Thanks for the reply, steppenwolf68. No, it seems to be happening with everything. I never had this trouble before. Not sure if this could be realted but I did have to lower my buffer size to get rid of a slapback thing happening when recording with my microphone. I tried changing the buffer back but the automation problem was still there. Could it be a buffer or ram thing causing the automation to go haywire? Do I have to reboot after changing the buffer or is it an automatic change? Any suggestions?
Old 09-06-2006, 08:01 AM
Thought I'd give this one final bump and hope for some suggestions.
Trouble with automation am I a fool? dope5050 Windows 0 04-12-2012 06:28 AM
trouble recording plug-in automation (wah pedal movement) on MIDI track lloydwatts60 Pro Tools 9 0 04-05-2012 09:37 PM
trouble with pan automation on PT TDM 7.3.1 gwenleb Pro Tools TDM Systems (Mac) 0 09-30-2007 02:21 PM
Suggestions for Automation Trouble? madlove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2006 02:16 PM
automation trouble - bizarre!! hyp0static 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-05-2001 06:58 AM
