#31
Re: WTB pro tools hd 12.5 with license
Asrock x79 extrême 6, intel i7 3930k, 16go ram HD native + Pro tools hd 9.0.6 + 192i/o analog and digital |
#32
+ don't have access to these drivers and i see only windows 7 humm i am on windows 10 ( its 64 bits) don't know if it would work?
#33
what can i do ?
thks
#34
If this succeeds, good luck!
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor |
#35
hello unkje you have this avid driver : HD Accel Stand-Alone Driver for Systems Without Pro Tools (HD9) for Windows 7 ?
a new case on my avid account or here ? cause i can't create a new case on my avid account ( i mean its not free )
#36
https://avid.secure.force.com/pkb/ar...411?popup=true Click on the blue arrow next to: “Pro Tools HD Interface and Device Drivers” Scroll down to the 2nd sub-heading: “HD Accel Stand-Alone Drivers for Systems Without Pro Tools” “These drivers are intended for use with Pro Tools|HD Accel hardware on systems where Pro Tools HD software is not installed. If you have already installed Pro Tools HD, you should not run this installer. The correct HD drivers are included as part of the Pro Tools HD software installation (Pro Tools HD 10.3.5 and earlier). Pro Tools HD Driver 10 for Windows [104 MB] For Windows 7 For HD Accel (TDM) and HD Native systems without Pro Tools” There may or may not be a workaround for using Reason, because I doubt if the Windows 7 Driver will work in Windows 10. If you still want to test it, you’d have to first uninstall Pro Tools 9 HD. Quote:
You’ve recently linked your iLok account with your Avid Master Account, (so check it again), but if there’s still no HD9 Bundle showing in your Avid Master Account, (even though you said your 192 Hardware has been transferred), it might be because your HD9 Bundle is listed in iLok License Manager as “No Transfer”. So, “Creating a Case” might mean paying Avid money and still not having your HD9 Bundle in your Avid Master Account, even though it’s in your iLok Account. If Avid do transfer your HD9 Bundle to your Avid Master Account, you’d need to buy a $499 Reinstatement https://www.sweetwater.com/store/det...e-expired-plan to get PT12.5 HD and/or higher for Windows 10, but please bear in mind what Dave already told you about Pro Tools 12.5 HD and upwards: Quotes: Originally Posted by albee1952 "If you are trying to use Pro Tools 9HD on Windows 10, this is not a supported combination. Windows 10 requires Pro Tools 12.5 minimum (and above, you would also need a separate digilink license on your iLok)." "HD/Native and 192 should be fine on Windows 10. I ran it 2 years ago and it was a really nice rig on a used HP Z820(12 core) with the HDN card connected to a pair of HD IO and a pair of 192 IO. No issues at all tracking 6 piece bands, even with 6 stereo HP mixes done in the sessions with sends. That system is still in use today." Accessing Software Installers on the Avid Download Center https://avid.secure.force.com/pkb/ar...ownload-Center If money’s tight, you could contact Microsoft to see if it’s still possible to roll back to Windows 7, so you can use PT9HD and Reason. Good luck! If any passing miracle-makers read this, the OP’s original 2012 Case Number: 01941334, "the name of the man avid tech is Mr Tristan Mazire he is french apparently cause i send to him my hd native card to update the firmware"
#37
#38
(I'll PM our expert albee1952 to see if this is correct) When you had Windows 7 installed, you also had Pro Tools 9.0.6 (with its included Driver) installed.
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor Last edited by unkJE; 02-15-2022 at 05:53 PM. Reason: added: When you had Windows 7 installed, you also had Pro Tools 9.0.6 (with its included Driver) installed. |
#39
Okay, this thread is getting really long and confusing so let me see if maybe I can put some clarity on it(great info is present, but its getting clouded by confusion and conjecture, and I am as much to blame as anyone). If you really want to run the HDN card and 192, you're probably going to need to upgrade to a newer version of Pro Tools HD(or Ultimate) as it appears that the HD driver, by itself, is not going to allow the Avid hardware to work with Reason. It has always been my feeling that Avid(Digidesign) hardware is excellent for use with Pro Tools, but NOT with other programs(like Reason, FL Studio, etc). If you really only wish to run Reason, I would simply grab any affordable 2 channel USB interface and remove the HDN card and 192 from the picture(you can sell them while they have decent value, or put them on a shelf until some future date when you can afford to buy Pro Tools)
Keep in mind that buying PT 12.5HD software(with the Transfer of Ownership) is going to cost upwards of $1000, and unkJE's suggestion of a re-instatement plan is another good option, though not the cheapest. A modest USB interface is going to be between $150 and $300(so if you don't want/need to actually use Pro Tools, getting a USB interface seems a "no brainer" to me). I realize this is not the answer we all hoped for, but at some point, I think it best to accept that we have hit a wall on making this work. Moving to a new interface WILL make things work, cost less money and allow the OP to start making the music he wants to make
#40
when I had windows 7 first time I had pthd9 installed and when I re installed windows 7 cause re format or others I just put my HD native with digi 192i/o but not necessary pthd9 installed.
Bought Pro Tools, but activation license is now missing in iLok license manager | JlrBrodie | Licensing & Accounts | 4 | 11-21-2016 01:25 PM |
FS: Complete Production Toolkit License, Pro Tools 10/9 license/Best Offer | DanSteinberg | Buy & Sell | 6 | 08-03-2015 12:03 PM |
Does the Pro Tools 11 Academic License include a Pro Tools 10 License as well? | EDF | Pro Tools 11 | 1 | 05-04-2014 03:47 PM |
Can not download Pro Tools 11 license to my iLok2 -incomplete license surrender issue | StereoZzilla | Pro Tools 11 | 10 | 01-04-2014 11:11 PM |
ilok - Cannot download license: Pro Tools 10+9 Bundle requires surrender of license | soukotta | Pro Tools 10 | 10 | 09-25-2012 07:22 AM |
