Old 02-22-2015, 03:08 PM
Rosco1969 Rosco1969 is offline
Default VCC 2.0 bug?
I just came across what I think may be a little bug.
I set up VMR with one instance of VCC2 inside with a group selected, for example, group 1 (any group does the same) as the default for VMR when it opens. All is fine and it opens with VCC inside as I set up... now, if I then want to copy that instance to another insert within protools (ALT-click n drag), every other instance of VMR with VCC set to group 1 defaults "all settings to zero". I've tried it several times with different groups and every time it has the same result. it resets all settings in all instances set to the same group.
Anyone else able to replicate this?
I have reported it to Slate support but just wanted to know if it was just me... lol
Rosco
Old 02-22-2015, 05:51 PM
zoff zoff is offline
Default Re: VCC 2.0 bug?
Rosco
Yep, all the pots go fully counter-clock wise!
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 02-22-2015, 05:53 PM
All center? Hmm... Mine all go fully anti clockwise. All the way to zero, if you will. Input fully down, output fully down, first console selected, drive fully down. Weird
Old 02-22-2015, 08:18 PM
zion zion is offline
Rosco
I'm not seeing this issue on my system. When I copy a instance to another insert it works as it should. All setting remain.
Old 02-23-2015, 02:52 PM
Dave Modisette's Avatar
Dave Modisette Dave Modisette is offline
I encountered a similar problem in Sonar Platinum and Studio One 2. With my scenario, I had saved my settings with group 1 as the default. When I closed the session and reopened it later, the input and output were set to -18.
Dave Modisette
www.gatortraks.com
Old 02-23-2015, 02:54 PM
Sounds like a very similar bug Dave. Have you reported your experience to Slate Support?
Old 02-23-2015, 03:00 PM
Zion, have you set up a default instance of VMR with VCC inside and set to group 1?
If so, make sure nothing is inserted yet, then, insert VMR (default with VCC) and then alt drag...
Old 02-23-2015, 05:44 PM
Yep! I have VMR setup with a default instance of VCC set to Group 1 and Alt drag to another Insert works fine. All settings remain as Group 1 in all inserts. Even after reloading song.
Old 02-24-2015, 12:14 PM
Just tried this on my rig and all worked as expected, with all settings retained. Things that make you go "hmmm"
Old 02-24-2015, 12:16 PM
Weird. Wonder why it's happening with some and not others. What the common denominator here?
HTML code is On
