Old 08-15-2014, 07:22 PM
Dave Modisette's Avatar
Dave Modisette Dave Modisette is offline
Default Access Violations in PT 11.2.1
Could not complete the Open Recent Session 4 command because Access violation occurred, unable to read location: 0x0000000000000008
This is happening on some projects but not in others. I am restoring 11.1.3 to see if the problem disappears.
Dave Modisette
www.gatortraks.com
Old 08-15-2014, 08:16 PM
Default Re: Access Violations in PT 11.2.1
I'm back on PT 11.1.3 and the problem project is working fine again.
Anyone with an idea of what the problem could be? FWIW, I tried several versions of the problem project and they all threw the access violations.
Dave Modisette
www.gatortraks.com
Old 08-15-2014, 09:19 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
When I've gotten that it turned out to be a clocking issue.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 08-15-2014, 09:33 PM
mrtomcat mrtomcat is offline
no problems here
Old 08-15-2014, 09:36 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
I have seen this error SEVERAL times when opening a session and after king an update or something like that.
for me my Mbox 3 Pro being reset or rather turned off and on and restarting the computer fixes it.
its a crazy thing in that the error doesn't at all lead me to think thats the cause but in the last few months and during times of updates and what not Ill leave the box on and install a new PT version then get the error when first opening it up...
I also pre maturely revered back and although it didn't take long to go back to my clone... I simply had to power cycle my interface and computer
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 08-18-2014, 08:03 AM
Thanks for the replies. I'll install the update and see if fiddling with the RME settings will fix things.
Dave Modisette
www.gatortraks.com
Old 08-18-2014, 08:28 AM
sw rec sw rec is offline
I have access violations occasionally on 11.1.3/Win 7, and they're ALWAYS at the same address.
Old 08-18-2014, 04:31 PM
Well I've installed the 11.2.1 update and the access violation window is back.
This time it says:
Could not complete the Open Session... command because Access violation occurred, unable to read location: 0x0000000000000008
A little different but it's the same location.
My soundcard is internal so there is no cycling it on and off. I've changed the Clock mode and buffer size and rebooted but I still get the same message.
FWIW, it's an RME HDSP9652 card.
Dave Modisette
www.gatortraks.com
Old 08-19-2014, 07:15 AM
Watching this intently...mine only does it when I'm recording, but when it does, it makes the track completely unusable. It's done it on EVERY version of 11 to date.
Old 08-21-2014, 01:28 PM
And I'm back in PT 11.1.3 and the sessions are opening as expected.
It's been suggested in the GearSlutz forum to create a new session and then import the problem session tracks into it.
I might get industrious and try that to see if it works or I might just stay safe and use the tried and true workarounds.
Hey, if I can make SONAR work for 13 years, I can make any software work for me.
Dave Modisette
www.gatortraks.com
Access Violations Using Dropbox - Need Help icenet Pro Tools TDM Systems (Mac) 2 06-22-2011 09:29 PM
Please help!!! Access Violations galore in PT 8 backroomstudios Pro Tools TDM Systems (Win) 1 11-23-2009 11:46 AM
Access Violations in Tiger radianrecords Pro Tools TDM Systems (Mac) 5 07-22-2009 09:23 AM
Access Violations Crookster Pro Tools M-Powered (Win) 6 10-17-2007 01:09 PM
Access violations have shut me down! Rubianes2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-07-2007 11:16 AM
