Eleven Rack problem
Hello,
I know that this kind of problem is easy to solve but not for me so I need Your help. I bought used Eleven Rack and I cannot setup it properly. When I plug guitar and headphones there is no sound. I tried different settings but nothing change even reset. Can someone of You dear Avid Comunnity write to me point to point how to setup this machne properly. I think my problem is in Output or Input settings. Thanks Paul |
Re: Eleven Rack problem
More info on your setup would be really helpful in narrowing down your problem.
Such as: Windows or OSX? What are the specs of your computer? What Pro Tools version? What firmware is on the Eleven Rack? Did you install the Eleven Rack drivers? ect.... If you think its just the IO, have you tried defaulting it? https://www.youtube.com/watch?v=rxZ9SgQm8H4 Since the unit was used it probably did not come with the manual, you may want to take a quick look at it to familiarize yourself with the interface: http://akmedia.digidesign.com/suppor...v90x_71670.pdf You can checkout my Youtube channel and/or blog for a bunch of Eleven Rack information as well (links below)
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks for reply, and sory for not enough important information about my machine. My Eleven Rack firmware is 2.01, Build 0.1.5.7 and it has the Expansion Pack.
Important: I don`t want to use Eleven Rack with PT and computer. I prefer use it alone, only with headphones and guitar. In the near future I`m goning to use Eleven Rack with some power amp, but now my rig is: guitar, headphones and Eleven Rack. Summarizing my post: When I plug guitar and headphones in to Eleven Rack there is no sound. Regards |
Since you got it used I would suggest to do a factory reset. Benoni shows how to do it here:
https://www.youtube.com/watch?v=Lk5mzKoPOIw |
Thanks for reply. I`ll try it, but my next question is:
What shoud I choice from User Options in Eleven Rack menu?: Rig Input - guitar ? Outputs to amp - ? Thanks Paul |
If you are not hearing anything through headphones, did you turn up the volume? Did you cycle the mute buttons? Did you adjust how the volume knob reacts ie what it adjusts? Take a look through the pdf manual I linked above, it covers all of the basic things you will need to know about the Eleven Rack in order to use it properly. You don't need to set the output to amp if you are not connected to an amp/pa/powered FRFR speaker ect... with one or both of the output to amp ports.
eleven rack - problem | hydra | Eleven Rack | 2 | 10-05-2012 01:12 PM |
Eleven Rack Problem | adflaker | Windows | 3 | 11-09-2011 02:27 PM |
Eleven Rack registration problem | iTwang | Eleven Rack | 3 | 05-03-2011 09:13 AM |
Eleven Rack/003 set up problem? | Ph.D | Eleven Rack | 3 | 02-15-2011 03:13 AM |
Eleven Rack Problem | Päng | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2010 12:54 AM |
