No "Eleven Rig" input option
Hey there,
I'm having some trouble with this new Eleven Rack. I am running Pro Tools 8.0.5 on Windows 7 64bit. I installed driver 1.1.7, which is the latest driver listed here on avid for the Eleven Rack. So, I start up a session and make a stereo audio track. The user guide says there should be "Eleven Rig 1" as an input option, but for me there isn't. So, when I try just using "input>interface>in 1-2" I AM getting signal from my monitors but it sounds like garbage. Low volume, fuzzy, very choppy like listening to a radio station out of your range. I've tried searching the internet for someone with the same problem but I can't find anything. Any help would be greatly appreciated. |
Re: No "Eleven Rig" input option
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
That did it! Thanks a lot for that. Unfortunately I am still have the terrible sound problem.
So, when I am just running my Eleven Rig through my monitors with no Pro Tools running, the sound is great both through my monitors and headphones. Now when I start Pro Tools, make the stereo audio track, choose "Eleven Rig L/R" and record enable it, the sound is terrible. I tried plugging in headphones to see if it was something going on with my monitors but I'm getting the same terrible sound in the headphones. Thanks a lot for your help, I'll start searching the internet for fixes on my current problem. Edit* SO I found this thread: http://duc.avid.com/showthread.php?t=320659 I change my USB cable, and that fixes it. Glad it was that simple. Thanks again for your help Benoni. |
Wow, so I found this thread: http://duc.avid.com/showthread.php?t=320659
And that was my problem...I changed the USB and it works fine. Thanks again for your help Benoni! |
I just upgraded to PT 11 (Win) today and had this same issue. Defaulted I/O to fix (thanks Benoni). However, all other new files I created had the same issue so it appears that the template for Guitar Tracking may be bad on the downloaded upgrade. Resaving the Guitar Tracking template fixed that.
eleven rack, pro tools 11 LE OS win 7 64 fractal design define r4 chassis m-audio audiophile 24/96 soundcard intel core i5 4440 3.1 GHz quad core CPU asus B85M-E Motherboard corsair vengeance 8GB DDR3 RAM seagate barracuda 2TB 6bp/s HDD thermalright 140BW true spirit CPU cooler samsung dvd writer corsair CX600 PSU |
cool man. glad to help.
PT 10 "new" software input monitoring option? | GKinTN | Pro Tools 10 | 46 | 08-10-2014 03:57 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Channel I/O keeps loading old I/O and not "no input"/"no output" | Arve Gotfredsen | macOS | 4 | 02-12-2013 04:38 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled | OKden | Pro Tools TDM Systems (Mac) | 2 | 10-27-2001 03:24 AM |
