Old 04-22-2013, 01:47 AM
sunburst79 sunburst79 is offline
Default Re: Can I connect my Casio keyboard to Pro Tools?
Originally Posted by isabellojello View Post
I have a casio ctk-4200 with one 1/4'' audio output, a smaller plug labelled audio in and a MIDI usb. What cables do I need to connect + record with my pro tools SE?
Not having SE or a CTK-4200 I'll make a guess. Connect the USB cable. Watch see if Windows installs drivers automatically. Assuming this is the case and the device is showing as correctly installed in Device Manager with any luck it will show up as MIDI controller in Pro Tools. You might want to re boot just for good measure after its installed. If the device is not USB class compliant than you need to hit Casio's website for a driver and install that.
If the keyboards has some built in sounds that you like you would run the audio out into your interface. Chances are if its one 1/4 output and the keyboard is stereo than its got a 1/4 stereo output jack and you will some type of 1/4 inch stereo splitter Y cable. Which you would connect to a pair of inputs on your interface.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Can't get no sounds from Casio WK-3000 keyboard on Pro Tools HipHopHead Pro Tools M-Powered (Win) 1 03-01-2008 03:14 PM
Can't get no sounds from Casio WK-3000 keyboard on Pro Tools HipHopHead Pro Tools M-Powered (Win) 0 02-26-2008 04:27 PM
Can't get Pro Tools to pick up Casio WK-3000 keyboard w/MIDI HipHopHead MIDI 0 02-26-2008 04:23 PM
Can't get Pro Tools to pick up Casio WK-3000 keyboard w/MIDI HipHopHead MIDI 0 02-26-2008 04:22 PM
CASIO Digital piano!!!! HELP mE cONNECT Friend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-30-2007 05:59 PM
