Soft samplecell problem
Hi all,
In the setup window for SSC the option for Direct I/O is grayed out. How can this be, nothing is mentioned about this in the manual. Furthermore, I am unable to audition sounds in SSC if PT is not running. Help please (Digi?) Cheers, Bob Lowen Setup: Mix3 + 2 SCII tdm in expansion chassis, 1622 on core, 882 on farm, G4 MP 500, MacOS 9.1, PT 5.1.1. |
Re: Soft samplecell problem
Look in your Extensions Manager. Do you have Digidesign Direct I/O installed and enabled? Is it a version that matches your other Digi Extensions?
(also make sure and open the Extensions Manager window all the way, otherwise you will get partial names, such as "...irect I/O") |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by bob lowen:
In the setup window for SSC the option for Direct I/O is grayed out.<HR></BLOCKQUOTE> -You cannot use DAE and Direct I/O simultaneously...is Pro Tools launched when it is greyed out? If not, check for the presence of the Direct I/O extension as legasus suggests. -Can you audition Soft SC if you choose "Sound Manager" from Setup window? Brent |
If you have a Midiman usb extension get rid of it and see what happens.
Brent, lagasus, thanks for replying.
Yes, Digidesign Direct I/O is installed and enabled in the extensions folder. I have the following installed and enabled Digidesign Direct I/O 5.1.1 Digidesign DSP manager 5.1.1 Digidesign Streammanager 5.1.1cs9 Digisystem INIT 5.1.1 Directconnect Data (n/a, no version given) Yes, I can audition when choosing Sound Manager, but only sounds on SSC not those on SCII cards, but I guess that is normal. This is in standalone mode, with PT I use Directconnect. Cheers, Bob. |
You can remove the "DirectConnect data" extension (I think that was used with the first version of DC that was released).
-Yes, hardware SampleCell cannot preview out of Sound Manager...you can only preview via the card's analog outputs except when running Pro Tools with the TDM piggyback. Brent |
Soft Samplecell problem | l anthony johnson | Digidesign Hardware & Software | 0 | 07-25-2002 11:13 AM |
Soft SampleCell Problem | Severe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-05-2002 12:05 AM |
Soft samplecell no audition problem | songman | Tips & Tricks | 0 | 03-17-2002 11:55 PM |
Soft SampleCell + ATTO Problem | Vinylizor | Pro Tools TDM Systems (Mac) | 19 | 01-02-2002 12:34 AM |
soft samplecell and 5.1 problem | cyclingbro | Pro Tools TDM Systems (Mac) | 3 | 07-09-2001 10:11 AM |
