VCC 2.0 bug?
I just came across what I think may be a little bug.
I set up VMR with one instance of VCC2 inside with a group selected, for example, group 1 (any group does the same) as the default for VMR when it opens. All is fine and it opens with VCC inside as I set up... now, if I then want to copy that instance to another insert within protools (ALT-click n drag), every other instance of VMR with VCC set to group 1 defaults "all settings to zero". I've tried it several times with different groups and every time it has the same result. it resets all settings in all instances set to the same group. Anyone else able to replicate this? I have reported it to Slate support but just wanted to know if it was just me... lol Rosco |
Re: VCC 2.0 bug?
macOS Sonoma 14.2 • Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM • Pro Tools Studio 2023.12, RME Babyface Pro |
VCC 2.0 bug?
All center? Hmm... Mine all go fully anti clockwise. All the way to zero, if you will. Input fully down, output fully down, first console selected, drive fully down. Weird
Re: VCC 2.0 bug?
Re: VCC 2.0 bug?
I encountered a similar problem in Sonar Platinum and Studio One 2. With my scenario, I had saved my settings with group 1 as the default. When I closed the session and reopened it later, the input and output were set to -18.
Re: VCC 2.0 bug?
Sounds like a very similar bug Dave. Have you reported your experience to Slate Support?
Re: VCC 2.0 bug?
If so, make sure nothing is inserted yet, then, insert VMR (default with VCC) and then alt drag... |
Re: VCC 2.0 bug?
Yep! I have VMR setup with a default instance of VCC set to Group 1 and Alt drag to another Insert works fine. All settings remain as Group 1 in all inserts. Even after reloading song.
Re: VCC 2.0 bug?
Just tried this on my rig and all worked as expected, with all settings retained. Things that make you go "hmmm"
Re: VCC 2.0 bug?
Weird. Wonder why it's happening with some and not others. What the common denominator here?
