PT11/Mbox3 have a problem concerning sample rate
I am using PT11 at the moment and I downloaded from IK Multimedia the demo of SampleTank3. When the midi-based software was ready it asked to use my Mbox3 as interface. I think it changed the sample rate to 44.1 kHz.
Now when I try to open my sessions with PT11 it says: "the current playback engine does not support a sample rate of 48 kHz." Before this everything was alright. I recorded today with PT11, but now I can't open the session (24bit, 48kHz). I have tried everything to change the sample rate of Mbox3, but I am confused. I re-installed the Mbox2 driver and even re-installed PT11. I deleted the also SampleTank3 and all the files that came with it. Now, what can I do? How can I make PT11 to open my sessions? Thanks! |
Re: PT11/Mbox3 have a problem concerning sample rate
You need to set your internal soundcard as the Windows default playback device.
Control Panel> Sound> Playback Right-click your internal sound card (not the MBOX) and choose "Set as Default Device"
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Hi.
Thank You mesaone for your reply. That really worked!! |
Yep, it works fine. I have the PC soundcard patched to a spare set of inputs on my console so I can still hear Windoze sounds.
Similar situation here. I use a analog mixer for routing and monitor control, I have my PC soundcard hooked up to the tape returns, while my interface is routed through channels 11-12. This gives me independent level control.
Hi again!
Windows 7 sound is running now by Realtek. I don't have a separate sound card in my computer, because I felt I didn't need one when I was building my PC for Pro Tools and internet use. My motherboard is Gigabyte GA-Z87N and processor Intel Core i7-4770K (8 RAM, 3 hard drives). Is it possible to listen Win7 sound with my Mbox3 without having this problem concerning sample rate issue (with PT11)? If yes, what should I do exactly? Thank you for your replies! |
003R+ & PT11 sample rate & buffer issue. | Nialzzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2014 11:21 PM |
003R+ to PT11 sample rate & buffer issue | Nialzzz | Pro Tools 11 | 0 | 01-11-2014 12:53 AM |
Can't change sample rate of Digi 002 rack in PT11 | Jstrat31 | Pro Tools 11 | 4 | 07-18-2013 01:41 PM |
Sample rate/playback problems with Mbox3 | algerij | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-16-2011 02:48 AM |
Sample rate/playback problems with Mbox3 | algerij | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-16-2011 02:42 AM |
