New pro tools le 8 program trying to hook up a mixer need help (old mixer)
How's everybody doin my name is de notes i'm tryin to see if I can hook up there mixer i got to pro tools le 8 up it is a eurorack mx 1604aKIND OF A OLD MIXER but it works.....Can it hook up to pro tools idk if it can, i hooked up everything and went to setup but it wasn't on tha list of mixers is there something I can do to hook it up to pro tools PLEASE HELP ME OUT
Re: New pro tools le 8 program trying to hook up a mixer need help (old mixer)
Um. Yes. At least, technically, yes. Run cables from the outputs of your PT interface (you didn't say which one) to the inputs of the mixer. ::shrug:: Not usually recommended with LE because of the limited number of outputs on most LE interfaces. More often used with HD, I'd guess.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
You can hook most anything up to your interface, but you MUST use a Digi/Avid interface(Mbox, 002, 003). Then its simply a matter of using the correct cables and the correct inputs to the interface. To use a Mixer, you would come out of the mixer and go into LINE inputs on the interface(usually TRS connections.
I got tha pro tools le 8 with tha m-box2 mini
Dont I have to go to setup then to midi midi studio setup or input devices and put in tha manufacturer and model cuz tha mixer i got is not on tha list |
The mixer wont show up in Pro Tools.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
so what plus do I plug in tha m-box from tha mixer I'm doin it now I just need a little help if u guys could thanks again everybody for tha help you guys are giving me
Assuming the mixer has quarter inch outputs, I would send the Left and right to the Mbox line/DI inputs(1&2) using good quality guitar cables(the mini is unbalanced anyway). As said, your IO in Pro Tools will only offer 1 and 2(corresponding to the 2 input channels of the Mbox mini).
How can I hook up my MIXER with Pro Tools? | AuthenticMillennium | Pro Tools 10 | 1 | 02-28-2012 08:12 AM |
mixer hook up. | rmessick2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-22-2006 03:59 PM |
(Help) If i hook up a mixer to the mbox????....... | idolizetravis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-27-2005 03:09 PM |
HOW DO U HOOK UP A DJ MIXER TO A MBOX? | MBE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-17-2004 07:00 PM |
how would i hook a mixer to digi design 001? | P-Loc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2003 07:59 PM |
