Old 11-13-2010, 04:48 PM
RobRaden RobRaden is offline
Default Advice for installing PT 9 crossgrade?
I currently have PT 8.04 on my Mac running OSX 10.6.4. I bought the PT 9 crossgrade box and it'll probably arrive on Monday. I bought an ilok and it just arrived today. What's the best way to go from LE 8 to PT 9? Am I better off uninstalling PT 8.04 first? How do I make sure I've gotten all of it off my Mac? I had bad experiences with my Mbox 2 crashing my Mac, so I'm not even planning on using it with PT 9 (I'll use my Apogee Duet instead).
I really want to make sure I'm starting from scratch with PT to avoid any problems. I'd appreciate any advice you have to offer here. Thanks!
Twenty200 - This is the world, the way I see it.
Old 11-14-2010, 02:14 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Advice for installing PT 9 crossgrade?
There's an uninstaller in the digidesign folder in applications.
You have 2 options "safe" and "clean" clean will be your best option for a new install like this!! also trash all your prefs after the uninstall, you can use this app to trash all prefs...
http://duc.digidesign.com/showthread.php?t=190122
repair disk permissions and reboot the mac before installing PT9
MAKE SURE ALL PLUGINS ARE UP TO DATE AND COMPATIBLE
Incompatible plugins are the biggest cause of unreliability and crashing!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-14-2010, 05:58 AM
producerdna producerdna is offline
I've installed PT9 on all of my computers (Mac Pro, Imac & MB Air) and honestly, either way is fine..
I used upgrade installer on mac pro & imac (from 8.0.4 to 9) and I used full clean install on my MB air and they all run fine..
I love running it on MB Air though.. Its just awesome..
Old 11-14-2010, 07:55 AM
crow crow is offline
The updater works fine - no need to uninstall PT 8
Just make sure your plugins are all the newest versions
I went from 8.0cs3 on Leopard to 9.0 on Snow Leopard using just the updater. Zero problems after updating a few plugs. Waves especially can cause crashes if you don't have the newest versions.
Also, your Mbox 2 should work fine if you install the new drivers.
Old 01-26-2011, 01:50 PM
ricky-lima ricky-lima is offline
Hello everyone,
If some one can help me please.
I`m using an Imac 10.6.2 snow leopard and digi 003+, PT 8.
My question is: To crossgrade from PT 8 to PT 9 should I update to 8.0.4 first?
Thank you guys.
Old 01-26-2011, 03:58 PM
Originally Posted by ricky-lima View Post
Hello everyone,
Thank you guys.
Shouldn't make a difference since it will want you to uninstal Pro Tools LE before installing PT9. I would double check that your running the latest versions of each and every plug when your done installing PT9. Might want to delete any PT databases first if your still on 8.0.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
[IMG] code is Off
Pro Tools 10 Crossgrade not installing on Mountain Lion penfold07 macOS 8 11-26-2012 02:31 AM
Re-installing after crossgrade. Stratomaster Windows 1 07-19-2011 08:08 PM
help installing PT 9 crossgrade -ilokked out End Over End Pro Tools 9 8 06-06-2011 10:39 AM
Installing PT9 Crossgrade on two computers? tragibigzanda Pro Tools 9 2 05-03-2011 07:10 AM
After installing Crossgrade, how would I reinstall from scratch? Doug Ring Pro Tools 9 2 12-20-2010 10:53 AM
