BFD lite? does not act as expected
OK , so first i have to say the sounds on BFD are very good. However despite reading the manual I'm wondering if this is some sort of psychotic crippleware to tease you with the sounds but is totally dysfunctional as a real tool unless you buy the full deal..
I've instantiated BFD on an instrument track. I wrote some MIDI notes into the MIDI track. The VU meter in the instrument track shows in the selected range for groove tracks. but only the first bar plays as per the play option setting I have set up. My thought as to how this ought to work is that I cam write notes into the instrument track in either the groove or fill ranges and create a drum track that way. Any guidance or links are much appreciated TIA as always B |
Re: BFD lite? does not act as expected
I'm not totally sure what you are describing, but I'll take a guess..
You are recording or writing in MIDI notes to trigger grooves, but the individual notes stretch to more that the length of the groove... Meaning your want the groove to repeat for the length of the MIDI note, even though the MIDI note is longer than the groove... I think there is a setting that will allow that, or you can just write in a new note to re-trigger the groove.. Take a look through the manual again... I'm pretty sure there is a switch in there for that.. Of course, maybe I misunderstand the problem you are having
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
I have tried all the different option in the BFD play window and I can't get it to work reliably B |
I just tried writing in some notes and it is working OK for me..
I have the edit mode set to grid so that the written in notes will snap to the exact beginning of the measure ( 2| 1| 000 in the MIDI event list for example) The play options I have set are: Respond to Groove notes is checked Transition Mode = Immediate Nothing else that might affect triggering.. Auto repeat and auto shuffle are off...
When is PT's 7 expected? | TCDet | Pro Tools TDM Systems (Mac) | 5 | 10-24-2005 02:05 PM |
Is this expected CPU usage ?? | subvertbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-12-2005 04:29 AM |
Digi 003. When is it expected? | JasonGough | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-18-2005 11:44 AM |
1.6 GHz G5 expected in 2 months! | Slaterman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-30-2001 05:02 PM |
G5 expected the next few weeks. | Seller | General Discussion | 0 | 11-09-2001 09:16 PM |
