44.1 works fine but 48 doesn't
Hi!
I have a question regarding my firewire connection to my 002r. I have Windows7 Ultimate 32 bit and are running PTLE 8.03.cs1. My daw is a HP DV6 laptop dual core 2.0 ghz The only thing that's work is 44.1 khz, as soon I bump up to say 48 I get the error 6087. No matter how much or little there is in the session I get this error. I know that my fw card is'nt the Texas Instrument one. So my question is if it's simply so that this card is'nt fast enough to keep up with the flow when going higher than 44.1? It can play for hours in 44.1 but just a few seconds in 48. Peter
https://www.facebook.com/petermartinssongroup/ |
Re: 44.1 works fine but 48 doesn't
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
Are you using a dedicated drive for audio?
And yes, you really should invest in a TI based firewire card to ensure solid performance with the 002. |
The thing is that I use an USB drive and can't replace the FW card.
But as I said it works flawless in 44.1 both record and playback. I tried the 8.04 driver but it made the 002 behave very strange. The 1394 light went on when I started the computer and switched off when I try to playback PT, weird. So I uninstalled it and everything went "normal" again. So for the moment I have no driver since I have to remove the 8.03 driver when installing the 8.04.
You won't be able to operate error free with a USB drive.
From this thread: General Troubleshooting - Pro Tools LE on Windows (XP & Vista) Quote:
I've been using USB drives for a couple of years now with another
laptop. It streams both recorded files and sample librarys just fine for my needs. Running at 64 and 128 samples when recording. But when mixing the single cpu is'nt enough. This new machine has the power but can't record or play 48khz sessions. Recording at 44.1 is ok with me but I can't play my older 48 sessions. I'm stuck with what I have for the moment. I just wanted to see if anyone could share some light over how the fw port is supposed to work. Have no xpress card slot either. Thank's!
"Caution: When running the Pro Tools installer on a Windows 7 machine, DO NOT plug in your LE unit when the installer instructs you to do so. This could cause installation errors. When you run the 8.0.4b Driver Installer, you will receive a similar instruction. Please plug in your unit at that time." I suggest you try the 8.0.4 driver again since I had the exact same error you're describing and installing the 8.0.4 driver solved it. EDIT: Also I would not install the cs1 update at this time. There have been issues with it. BTW the issue I had after installing was a unrelated issue with the mbox 2 have crackling issues which should not be the case with you. Windows 7 audio drivers info
PT 10.3.4 works fine on Air but Express won't.. | Piers Gibbon | Pro Tools Express on Mac OS X | 9 | 10-31-2013 01:45 AM |
HELP PT works fine one day and not the next! | oddeodude2012 | General Discussion | 1 | 03-17-2005 12:02 PM |
My 001 works fine, should I go 002? | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 08-17-2004 02:02 AM |
Nview works fine BUT NOT ON PT anyone? | lie-ability | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-09-2003 09:05 AM |
My Pc works (now) fine with PTfree--> | jdmatt | Digidesign Hardware & Software | 1 | 11-04-2000 12:59 AM |
