Digi 002 works fine, but no sound device in Windows?
I was under the impression that Windows would see any Digi hardware as a sound device. I have the Digi 002, and even though it works fine with ProTools and WMP, when I go into sound devices in Windows XP, is says "No Audio Device" and there are no choices to select one. So I can't get any audio to play out of my pc unless it's playing from ProTools or WMP. Can the Digi002 be THE audio device for Windows XP?
Re: Digi 002 works fine, but no sound device in Windows?
The ASIO driver should allow this but I prefer another method. I run a cable from the onboard audio output to the ALT inputs on the 002/003 and hit the ALT to NOB button to listen to any non-protools sounds.
Interesting idea. I thought I'm supposed to keep my onboard sound disabled when I have a PT hardware connected, but if it works for you I'll give it a shot. Thanks.
I have the on-board audio enable on this setup and my 2 older ASUS systems and have never had an issue. The Sound Blaster stuff seems to be more trouble.
iTunes, browsers not making sound, PT10 works fine | drwlxndr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-18-2013 08:29 PM |
Pro Tools 8 LE, Windows 7 Ultimate (WORKS FINE) Can i enable Previous Versions (VSS)? | Toonyan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-13-2011 02:11 AM |
PT7.4 Works fine, no sounds from windows though | Darryl D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-01-2007 10:28 AM |
Start PC - no sound. Restart PC - works fine! | konsultimedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-05-2007 01:17 PM |
usb input device that works w/ Sound Manager | rossbf | Digidesign Hardware & Software | 3 | 03-24-2001 03:37 PM |
