Multiple sound cards.
I have a delta 1010 and 410(firewire). Pro tools sees both of them in hardware setup, but when you go into the i/o to assign your inputs it does not see 410, eventhough when 1010 is not pluged in it does see 410... help...
Re: Multiple sound cards.
this cannot be done = 1010 + 410.
however, if you get another 1010 card, it can be done. so the "rule" is that you can have multiple "delta" cards, but not mix and match any other m-audio hardware. sell the 410 and get another delta.
http://www.myspace.com/blaqmusicgroup |
410 is not mine 8-) just want to have a couple more room mics for drum recording.
can't be done.
you are only allowed to use multiple "delta" cards with pt m-powered.
Are you allowed to use multiple "anything else" with MPowered? Multiple 410s or 1814s for Mic inputs would be nice.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
no.
only "delta". didn't i say that already above?
so any delta means that i can get lt version or any other and do that?
yes, that's what i said above.
I thought that M Powered doesn't allow ANY multiple cards. I know the Delta cards can be chained with other DAWs but when I first installed mine, it said that Pro Tools MP did not support multiple cards.
i use multiple 2496's
many on here use multiple 1010's yes, it can do it, and it is tightly integrated that way.
Multiple Sound Cards | txrx | Windows | 3 | 09-27-2012 12:23 PM |
Multiple Sound Cards total 24ch | Rithem | macOS | 0 | 12-28-2011 03:50 PM |
Multiple HD core cards in one Mac? | projector | Pro Tools TDM Systems (Mac) | 1 | 09-09-2009 05:35 AM |
Multiple AM3 cards? | Paul Southworth | Digidesign Hardware & Software | 1 | 08-29-2002 09:16 PM |
Multiple Project Cards | Brensolo | General Discussion | 1 | 10-07-1998 06:11 PM |
