Re: Big Sur 11.6
Been running 11.6 for awhile. I just updated to 11.6.1. No noticeable issues on my system.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
Re: Big Sur 11.6
Can you share the workaround? I am having issues where the HDX cards just never wake up. I dug deep somewhere and it said to load the kext file...that makes HDX a usable Playback Engine but it doesn't actually work...once you load a session and hit play I just get AAE -6001 (driver error). Thanks, Keith |
Re: Big Sur 11.6
Thanks for the suggestions everyone.
Dave Pro Tools Ultimate 2022.12 / OSX Monterey 12.6.2 Avid HD Omni / HD IO 8x8x8 / HDX Sonnet Echo Express 3 iMac Pro 3GHz, 10 Core, 64 GB |
Re: Big Sur 11.6
Check the links on the site - they are all Apple hosted.
Re: Big Sur 11.6
I noticed yesterday that Avid quietly updated the PT 2021.10 requirements a couple of days after initial release. The day of release, it still stated Big Sur 11.5.2, now it says 11.6.
Of course 11.6.1 is now out but I've had no issues on my system.
Re: Big Sur 11.6
_______________________ From Avid Support: You need to remove (delete and empty trash) the Avid Audio Server folder and .plist file: https://protect-us.mimecast.com/s/s0...cure.force.com ________________________ Hope this helps
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Re: Big Sur 11.6
We're having a problem with 2021.10 installing the HD Driver for HD Native. One system out of three WILL NOT install the driver. We reverted that Mac back to 2021.7 and it's fine. Have posted about this somewhere else replying to other users with the same issue.
Re: Big Sur 11.6
Updated to 11.6 Big Sur and now the HDX card is not showing up. Tried reinstalling HD drivers and the old preferences trash but no dice. Going to contact support unless anybody’s found the solution.
Re: Big Sur 11.6
https://avid.secure.force.com/pkb/ar...All&popup=true
