Old 06-29-2022, 10:58 AM
JingleDjango JingleDjango is offline
Default 2022.4 - Clips List Sorting Woes
I have new session with an empty timeline and some freshly imported clips in the Clips List. The Clips all have the same names as their parent filenames because I've done nothing to change them since importing them.
Why then if I toggle the Sort by option between Name and File Name do I get wildly different results?
...and why does there seem to be no inherent logic to the way the clips are sorted when I select File Name?
Sort by name:
https://imgur.com/4RWZYOJ
Sort by File Name:
https://imgur.com/7dXW9Pj
If I sort by Disk Name I get results the same as sorting by Name. So what's the difference between File Name and Disk Name?
Lastly, none of these sorting styles follow the same rules as the Mac Finder or Excel alphanumeric sort!
Old 06-29-2022, 11:24 AM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: 2022.4 - Clips List Sorting Woes
Look in this screenshot:
Test-Track_01 is an existing Disk Name for the file underlying the whole clip (on the Left) the dialog is for naming just the clip or also the disk file.
On the right, is a whole clip separated once, and on the dialog just says Name, because the clip does not represent a whole file but just a portion of it.
The clip list can sort by Disk Name (which can be the same for a whole bunch of separated clips) or by Name (which to name clips you have to double click to make the dialog in my screenshot, or use the batch rename utility to do for many clips).
Various operations, such as audiosuite or other edit renderings can create a whole array of random but unique disk names, but the clips can be another whole array of random that is sometimes not exactly related to the disk name.
Do you have other questions, or does this make sense of the issue?
edit: one extra thing. alphanumeric sort can be a LITTLE misleading in different parts of a computer. Example, what is first, second, third, and fourth in the list:
Name0
Name1
Name00
Name01?
What if - _ $ characters are in the name?
I would press you to see if it is just a bit odd to pick, or if you see there could be an argument for potential choices for ordering. Especially if a computer program MIGHT sort - before _ and the OS does it differently.
Yes, there are standards, but trouble is more than one. Maybe the hexadecimal software A3 got coded by Windows as MacOS binary 001010 or WHATEVER, but what that represented is - or _ so the sort gets mixed in some other software. So that's a potential issue for sorting. Maybe it's simpler in your situation, or it could be a little arbitrary and convoluted
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Last edited by nednednerb; 06-29-2022 at 11:32 AM. Reason: OS and PT sort differences
Old 06-29-2022, 11:36 AM
Thank you for trying to add clarity. The User Guide says this:
File Name Displays the parent file name.
Disk Name Displays the name of the hard drive on which referenced file resides.
I understand now the difference between File Name and Disk Name but don't understand why they would sort completely differently. I have no child clips auto-generated by edits or renders or anything. The timeline is completely empty at this point.
Edit: And yes you're right it's perhaps unfair to expect Pro Tools to sort by the same arbitrary order as the OS but since all of the other software I use seems to agree on which characters should sort to the top I'm getting frustrated. I see why everyone is migrating to Reaper for programmatic/game audio.
Old 06-29-2022, 12:02 PM
nednednerb's Avatar
One mistake I made:
See screenshot regarding difference between File Name and Disk Name....
Disk name is the volume (your hard drive), meaning you'd have to sort by Disk Name THEN another sort, or it will be a weird order probably.
So maybe what you want is (clip) "Name" and "File Name" to make more sense of it.
Maybe Disk Name sort then is followed by Time/ Date or another parameter, hence the weird order between Disk Name and File Name sorts
File Type: png Screen Shot 2022-06-29 at 12.01.05 PM.png (10.3 KB, 0 views)
___
>> me: nednednerB //
Old 06-29-2022, 12:06 PM
But my clip names and my file names are one and the same, so it begs the question. . .
I have no idea why Clip Name and File Name results in irrationally different sorting results.
Old 06-29-2022, 12:08 PM
nednednerb's Avatar
Also, Reaper is totally free. I was there first, then went to audio school and learned Pro Tools, and at this time I wouldn't consider changing as in jumping ship, but it could be valid route for others. Software UI and under the hood operation is similar to vehicle controls and engines. Add in "SMART" so called technology of present date, and it gets very different what individuals can even learn well enough for themselves. One size does not fit all.
___
>> me: nednednerB //
Old 06-29-2022, 12:12 PM
nednednerb's Avatar
That is strange.... When I do sort operations on some clips, it makes sense to me. I'm not sure what the exact state of your file and clip names are or why it doesn't make sense for you.
Hmmm.
___
>> me: nednednerB //
Old 06-29-2022, 01:05 PM
Here is a short clip of me importing the clips into an empty session and sorting the Clips List:
https://youtu.be/-cBDRYC130k
I still don't understand why sorting by Name vs File Name gives different results.
Old 06-29-2022, 01:32 PM
nednednerb's Avatar
Did you check the file name in the Audio Files folder? Did they get renamed for some reason?
Yes, I agree it seems very strange without a logical reason
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
Old 06-29-2022, 02:47 PM
smurfyou smurfyou is offline
Reaper is not free. That's repeated a lot but it is not free.
~Will
sorting clips in clip list martthie_08 Pro Tools 10 3 06-24-2023 12:27 PM
Pro Tools Studio 2022.05 is not showing video in the clips list Kewbass Windows 3 06-23-2022 10:35 AM
Clips Sorting - Numbers or Characters First? DrewHarrison Getting Started 0 09-15-2020 12:09 PM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Help with clips bin sorting please Michael Wilk Windows 0 06-27-2013 01:09 PM
