Old 02-16-2011, 12:32 PM
appledude appledude is offline
Default Re: PT9 teething problems
Originally Posted by Digiwave View Post
Aggregate I/O is not selected on hardware, it shows profire 2626 yet in my track mixer its showing built-in I/O for input 1/2 then 3 to 26 on my profire.
Check your playback engine. If it shows the Profire 2626, then go to the I/O and hit default button. This should set the I/O as a default fro the Profire 2626.
Imac Pro 27" 10-core with a LG 4K for a second screen
OS 10.14.4
Pro Tools 2019.6
UAD Apollo X8P With an extra 8 channel ADAT using
a Focusrite Liquid Saffire 56
UAD Twin duo
UAD TB3 Octo Satelite
Focal Twin Be monitors
samsung T5 and Gdrive
Old 02-16-2011, 03:56 PM
d.f. d.f. is offline
Originally Posted by nozzles View Post
I too received poor performance results with my crossgrade install (essentially a fresh install - ie. no previous version of PT on the machine). I couldn't throw many plugs on without overload errors ... my fix was to read the link in Avid customer support around machine setup. I unistalled Pro Tools. I set up a new admin account on my machine with pretty much everything off (Airport, bluetooth etc.) and no 'bells and whistles' software. I installed Pro Tools on that account, and I've had no probs. Prior to this my machine would crash around 30%, easily. Since that fix I have run up to 60% System Usage!! (At that level I do need to move the engine to 1024) RAM will also help (I increased mine up to 6GB, go at least 4GB).
hope that helps!
PT9
MacBook Pro 2.4Ghz, 6GB RAM
Digi 002R
MOTU 896
Apogee Duet
Mbox 2
Very interesting. I might try this as mine has been crashing too.
Old 02-17-2011, 01:14 PM
Digiwave Digiwave is offline
Went on hardware.... set the default to profire 2626... yet still getting built-in I/O on input 1/2.I can here the clash in hardware!!
Old 02-17-2011, 02:49 PM
Hmm... not sure we are on the same page.
First - start your ProTools software and load your session.
Second - Under the Setup Menu click on Playback Engine... You should see what your current engine is and your buffer size. It should say Profire, if not click and select it.
Third - Under Setup Menu choose I/O.... Hit the default button. It should adjust to show all of your inputs and outputs. You can then edit them to say what you want. When all is correct, you will be able to chose these in your ins and outs and sends.
It really sounds like you have the built in I/O chosen for the playback engine. go to the playback engine you will see the what Pro Tools is using. Also what are the three plugs that you have loaded when you get an error?
OS 10.14.4
Pro Tools 2019.6
UAD Twin duo
Old 02-17-2011, 10:47 PM
Dverb x2, LongDelay
I had the error problems when I first got 8.3 and had to go back to 8 for it to work stable, is it worth trying 9 instead of 9.1?
Teething Troubles Folkybass Getting Started 1 07-08-2013 06:31 AM
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Computer Problems vs Pro Tools Problems mudlake slim Pro Tools M-Powered (Win) 1 07-14-2006 08:09 PM
Rewinding Problems, Cutting & Pasting Problems Nikki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-22-2005 01:19 PM
PC Probe problems. Any overheatingg problems with Digi 001 Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2002 05:30 PM
