#51
Re: Its time to sue digi/avid????
Das Leben ist wie eine Schachtel Pralinen, man weiß nie, was man bekommt.
#52
Here's hoping for a lock to finally put this one out of it's misery. Carey |
#53
#54
When you sue someone, you ask for some sort of damages. I don't see the OP asking for anything, just complaining. What does he expect to get if successful?
If he spent his time troubleshooting and getting help here, he could be up and running. Nothing made by man is perfect. I am not aware of any software that stopped at version 1.00. There will always be fixes and improvements to any successful program. My PT9 is working fine.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#55
I'm surprised there are people still using it. I was one for years until Nuendo4, but by that time I already had 3 LE systems. The convoluted way Cubendo works versus PT is another. There are bugs, I have a number of annoying ones with Automation Follows Edit and plugins, but the work around is simple. That being said, I've known a number of Cubendo users who jumped ship and went PT 9. I've had little problems with PT or the Core audio drive. Well, none actually across LE systems, and HD systems. They all work. One thing seems to be common though with threads like this on any DAW forum. People have cluttered OS drives with crap from everything on the system, update every new OS that comes out that day and so on. Its easy to partition a drive and have a PT drive, an a General drive, and a Final Cut drive. Takes 30 seconds to reboot into it. Start over. Wipe the system, reinstall OS from scratch and install PT on a separate partition. I think you are going to be hard pressed to find people to follow your issues for a lawsuit, when I suspect the problems at hand are more the users fault then the softwares fault. I created a separate PT9 partition, finally deleting PT 7.4.2, to keep my PT 8.03 partition alive. When I installed PT9, I haven't went back. It just works. I bring HD session home all the time and take them back. No issues. VCA's are there, all the tracks are there. And I have a Mac mini currently and run a ton of tracks. The issue is on your end dude. |
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift | Franco1967 | Pro Tools 11 | 1 | 01-25-2014 11:31 AM |
Avid - I am really hurt this time... | meshzu | Pro Tools 10 | 32 | 02-19-2012 08:16 PM |
Avid time or Digi time? | @ndy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-31-2009 08:16 PM |
DIGI FEEDBACK: 'Real Time' Bounces-Time Effective? | csiking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-20-2005 06:41 PM |
Time Code in OMF export to AVID? | Tim R. | Pro Tools TDM Systems (Mac) | 0 | 09-29-2000 09:40 PM |
