Old 02-18-2011, 02:15 AM
MrBibidy MrBibidy is offline
Default ProTools 9 developing NOISE after 10 hrs work
I've been pulling LONG sesshions often working for 12 hours at a clip. EVERY single session without fail I have seen this issue. After about 10 hours Pro Tools audio playback will either start breaking up in time and with digital distorion or I will get an ascending tearing sound at seemingly random intervals which develops into progressive and regular intervals about one ascension per 3 seconds. I can repeat this issue because I have experienced it every night I've been working.
Solution, restart tools.
Also PT 9.0.1 seems to have bug when importing session data from a session with different I/O, it will crash upon import when it reaches the point at which it reads the I/O from the source session.
Solution, delete prefs and databases and restart. NOTE: this DOESNT always work.
James Hurley,
Int'l Freelance Producer & Mix Engineer
http://www.Abravemix.com
Old 02-18-2011, 07:53 AM
KMcK KMcK is offline
Default Re: ProTools 9 developing NOISE after 10 hrs work
The second one I've seen and I believe has been reported in other threads. The first one I haven't, and I have Pro Tools 9 open and running well over 10 hours per day most days and on multiple rigs. What is your system info? Perhaps you have something in your rig that is overheating after extended hours of use (i.e. your cpu)?
Old 02-18-2011, 11:45 AM
Jeffrey Talbot Jeffrey Talbot is offline
And while I'm not using mine solidly for 10 hours, it stays open, up and running 24/7(except weekends..), and I haven't noticed anything... Granted, its not the same as your use, but still...
Old 02-18-2011, 01:59 PM
VERY interesting.... Glad its working for you guys...
Im running a 15" MacBook Pro 2.66 Core 2 Duo, 4GB ram with OSX 10.6.6, Mbox 2 Mini, PT 9.0.1
James Hurley,
Old 02-18-2011, 04:20 PM
DigiTechSupt's Avatar
If you check the Console logs - what's happening at the time the distortion starts to occur? It's probably a pain to be there at the very moment the distortion starts, but we'll need some clues as to what may be triggering it. I definitely don't see it here and I've got Pro Tools open for well over 10 hours every day.
Avid Audio Tech Support
Support FAQ
Old 02-18-2011, 04:29 PM
I know its a bit weird.. I've never noticed it till i updated to 10.6.6.
How can I check the console logs?
James Hurley,
Old 02-18-2011, 05:45 PM
Just launch the Console application (from Applications>Utilities>Console) and open the tab on the left for 'Files' then click on 'System.log'. You'll see a running itemization of what the system is doing at any given time - something in there may indicate what's causing the problem.
Or, if you can identify the exact moment (within a minute or two) of the distortion starting, you could save the log and email it to me at : vi [at] digidesign [dot] com and I'll take a look to see what may be causing it.
No promises, but we can give it a shot...
Support FAQ
Old 02-18-2011, 05:47 PM
Will do.
James Hurley,
DAE -6088 & -6085 ... common thread developing here! dbrunell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-08-2009 04:41 PM
Is Strike still developing? joerusi Virtual Instruments 9 06-03-2008 06:48 PM
developing my own plug-ins rageagainst Virtual Instruments 1 04-19-2006 08:08 AM
anyone interested in a skill developing group? badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2002 07:54 AM
OT.. Mental Problems Developing. Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 129 09-22-2002 08:35 AM
