Analogue board upgrade...
Hi guys,
I have not so far used the analogue section of my PC (2.5 yrs old) but am now setting it up to use the surround monitoring facility. Q: Is the analogue board upgrade to early PCs necessary (I have never even heard the original yet [img]images/icons/blush.gif[/img] )? Looking at the serial numbers I believe my PC requires the upgrade. Thanks for any feedback. Peter Williams The ZeroSphere Cambridge, England
The ZeroSphere Ireland |
Re: Analogue board upgrade...
Hi Peter,
The analog upgrade for ProControl provided two enhancements. It reduced a crosstalk problem where you could hear a neighboring input bleeding through softly if you weren't playing back through the main input, and it also eliminated a small DC offset issue that could cause a click when you changed input sources. The other aspects of the monitor system -- noise, distortion and frequency response -- remained largely unchanged. As to whether you need the upgrade or not, I would suggest setting up your monitor system and seeing if you have crosstalk or click issues. I believe there was also an early issue with the monitor section where the absolute polarity was inverted on outputs. There was a replacement connector board made available for this although I don't know a lot more than that. Regards, Stan Cotey |
Comm Board Upgrade pricing | NGuise | ICON & C|24 | 2 | 05-20-2010 06:43 AM |
using an mbox and a Mackie 32*8 analogue board | sir d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-08-2004 03:20 PM |
Best Analogue/Analogue Modeling Synthesizer??? | David Fisher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-15-2002 12:30 AM |
Monitor Board "Upgrade" | bairtracks | ProControl, Control|24, Command|8 | 30 | 04-01-2001 03:35 PM |
Monitor Board upgrade and New Users? | PlanB | ProControl, Control|24, Command|8 | 2 | 11-23-2000 09:03 AM |
