Re: Direct Connect whit Pt le 5.1
You could try to change the DAE to 5.1.1.I think that is possible.
Tobbe |
I cant enable the audio busses in the Direct connect panel in Pt le 5.1, digi 001 Mac G4 350 AGP Card, 256 Ram, Mac OS 9.0.1.
Using an older version of PT (5.0.1) the direct connect works perfectly and i can use instruments like soft sample cell or NI Absynth whitout problem but whitout the features of PT5.1. Can you help me? P.S.: I have the same problem in a PT|24 Tdm Sistem. Pro Tools Tdm needs mix cards to enable direct connect option? Thanks. Thomas. |
What version of the DC plug-in and Digi Stream Mgr plug-in do you have installed? You should have v5.1 of each installed for compatibility with PT LE 5.1. Make sure no duplicates or older versions are present.
Brent |
I just have in my system DC plug-in + DigiStream both v. 5.1!
The DAE version is 5.1. I have downloaded the DAE 5.1.1 and i'm tryin whit this. The digidesign support page recommends this DAE version for PT 5.1.1, but It's already true that i use whitout problem the old version of PT (5.0.1) running on DAE 5.1!!!! Other Suggestions? Thanks. Thomas. [img]images/icons/confused.gif[/img] |
Using DAE 5.1.1 doesn't fix the problem!
Maybe i must update the direct connect plug-in too. Thomas. P.S. FOR TECHNICAL SUPPORT: For upgrade my PT-24 tdm system to enable direct connect option can i simply put a mix farm card in my Mac or i must change the core system to a Mix Core? Thanks. |
PTF and direct connect 1.1 | Gothboy | Digidesign Hardware & Software | 0 | 03-17-2006 10:19 AM |
direct connect | evilegg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-17-2002 12:39 AM |
Direct-Connect BUG? | Henrik | Pro Tools TDM Systems (Mac) | 16 | 11-29-2001 01:09 PM |
Direct connect | littlebear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-07-2001 07:54 AM |
Direct Connect for NT? | Echo studios | Pro Tools TDM Systems (Win) | 1 | 06-29-2000 03:25 PM |
