#51
Re: June update - hybrid info
As I have seen hybrid mix engine do exactly what you say above can’t be done. (Someone else’s rig) |
#52
I did my best to look thru the 1,500 page protools 2021.6 users guide PDF to try to find specific details about hybrid mix engine, but could not find it.
Am I blind and it is there? Info such as tips to best use hybrid mix engine with HDX cards Any PDF user guide (specific to HDX and ultimate and hybrid mix engine) floating around? I can’t find it. ….. And I assume you can select a range of tracks and Option click on the lightning bolt ⚡️ a Mac to put a range of tracks all into DSP mode at once? |
#53
It’s pretty clear. You can mix DSP and Native plug-ins in the same session. You just can’t mix them on the same track! One workaround for using native plug-ins on a DSP track is to stick the Native plug-in on an Aux track and put the Aux track in DSP safe mode.
#54
Perhaps a moderator (or anyone) could post a link to a PDF where I can read more? It isn’t clear to me without reading some detailed AVID info. Away from my rig these days so can’t just figure it out. Thx. |
#55
What is it you are trying to figure out?
In Hybrid mode you can't mix DSP with Native on the same track. With Hybrid turned of on an HDX system you can mix DSP with Native on the same track, the way it has always been. |
#56
i am just trying to RTFM |
#57
There is good info in the latest reference guide starting on pg 1153. Hope this helps!
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
#58
SO I am assuming you mean just the track/s you had just recorded and just took out of record ? Then also it is so quick simply hit the DSP button on as single track or highlight multiple tracks and use the Key command to take them all out or into DSP . So I am not sure how much time you would actually be saving. I suppose It could be simply a difference of actual workflow ?? I do however have my DSP preference globally set so tracks automatically go into DSP when I hit either the Record Enable or Input Monitor buttons.
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#59
Now I am assuming everything is the same between Carbon and HDX Hybrid. The only workflow difference I am aware of is that in HDX you can toggle the playback engine between either Hybrid or Classic (classic if say for example for recording you definitely want to have both Native only and DSP plugins on the same track. So anyway in this video you will see me toggle multiple tracks into and out of DSP mode ( note as far as performance numbers this is the built in Carbon DSP card) which has 8 actual DSP chips, where each HDX card has 18 so I am assuming twice the power for processing https://youtu.be/0Qz2lcE9I0Y
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 06-25-2021 at 12:39 PM. |
Info on the AIR Hybrid Upgrade | DonaldM | AAX Plug-ins | 8 | 05-12-2014 01:30 PM |
Smack & Hybrid not working after OS update! | KingAce | Pro Tools 10 | 7 | 02-05-2014 01:21 PM |
Hybrid update | rabs | Virtual Instruments | 1 | 06-05-2008 12:00 AM |
Hybrid Update | rabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-03-2008 02:19 PM |
Can't Install Hybrid update or Velvet | sirgant | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-01-2008 01:14 AM |
