how to find non-existant input path/buss assignments?
YANQ (Yet Another Newbe Question) but I did try searching...
Working with sessions moved from another studio: open PT (10.2) and it complains about missing stuff. I look at the detailed report and it says The input path "36" was made inactive because its stem is missing. OK, I don't have an input path "36", so how do I eradicate this? Also, there are a ton of buses defined in the IO setup. I tried to clear these, and create my own but it says they are in use. I look at the mix window and I see no insert and no sends and no input or output assignments to any buses at all. In fact all the insert and sends are clear.
PT-10, windows 7 64 bit, currently i7-930 12GB, all SSD Burl ADC, Apogee DAC & bunches of outboard from analog days. Pretty good ears, just missing a lot of stuff in between... |
Re: how to find non-existant input path/buss assignments?
Any hidden tracks?
Lincoln Mitchell Pro Tools | latest Mac Mini Server | OSX | Current 16GB Ram | SSHD Apogee Ensemble Thunderbolt |
One thing that can help is to open the Setup>IO window and bus tab. Look down the right side for anything in italics. Uncheck those and save the session.
Thank you gentlemen,
Once again this forum has served me well. There indeed was a hidden track, for a keyboard that was not actually used, so I didn't think there was a missing track. old dogs can indeed learn new tricks.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Aux buss path going to wrong buss? | [email protected] | macOS | 3 | 10-10-2013 08:50 AM |
Input path n/a problem | Hugh Jazz | macOS | 1 | 12-10-2011 01:55 AM |
input assignments reverting | travista00 | Pro Tools TDM Systems (Mac) | 18 | 03-13-2011 06:55 PM |
Changing track input/output assignments corrupts session files, causing PT to crash. | horribleheaven | Pro Tools M-Powered (Win) | 1 | 07-08-2010 11:47 AM |
any Ideas? Cannot find specified path error message | TheLEM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-15-2009 12:48 PM |
