Old 11-24-2020, 07:53 AM
moshuajusic moshuajusic is offline
Default How do I undo a plugin parameter change?
Turning the wrong knob does happen. Is there an undo for Avid plugins? (Hopefully it's staring me in the face and I'm just not seeing it.)
Old 11-24-2020, 11:21 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: How do I undo a plugin parameter change?
There's a setting in your preferences to include those types of changes in your undo history.
Preferences > Mixing > Automation section > check "Include Control Changes in Undo Queue"
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 11-24-2020, 11:34 AM
devinemke's Avatar
devinemke devinemke is offline
just to be clear, this only affects automation changes. if you simply change a parameter on a non-automated plugin, then that will not be in your undo queue. not clear from the OP if that is what was intended.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Yeah, that's for mixer automation, and already checked. I wanna be able to undo things like adjusting the high pass frequency in EQ3-7 (within the plugin, not automation).
Old 11-24-2020, 11:38 AM
Ryan Young's Avatar
Sorry if I misunderstood. Just to check, is your plugin set to be automated, and is that track in something other than "off" or "read" mode?
-Ryan Young
Additional Systems
Old 11-24-2020, 11:54 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by jscomposer View Post
...undo things like adjusting the high pass frequency in EQ3-7 (within the plugin, not automation).
Gotta do it in the plug then
Click for audio/video demo
Click for resume
Old 11-25-2020, 04:20 PM
I don't know what "set to be automated" means. If I need to automate something, I click on the automation icon in the plugin window and add the parameter(s), then draw the automation. Tracks are typically set to "read." I only occasionally turn it "off."
Put another way, if I open a plugin and change a parameter's value, then hit command-Z, it doesn't put the parameter back to where it was. But I want it to do that. Waves plugins all have their own undo/redo buttons which are very helpful. What's up with Avid not allowing such a basic ability? (Or maybe they do, and I'm missing it.)
Nothing but "Undo Change Control Value" in undo queue WinstonDeath Pro Tools 11 18 02-22-2023 12:45 AM
Plugin parameter changes in Undo/Redo DJ Hellfire Pro Tools 12 0 07-15-2016 03:08 AM
Undo not working when pasting automation to a different parameter johan2006 Pro Tools 12 0 12-15-2015 11:01 AM
LE 7.4.2 Crashes to the desktop with TL Space size parameter change cpdroz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-09-2009 01:06 PM
How to change automation playlist by clicking on plugin parameter rmonday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-14-2008 08:57 AM
