Reason and Rewire problem
Hi all,
I've been running PTLE7.3 for a few days on my brand new macbook pro and with my new 002r. Everything is working perfectly for me so far except for when I try to rewire pt and reason together. Reason is not showing up on my list of plugins in the inserts menu. I am using Reason Adapted that came bundled with PT. Reason runs fine stand-alone, but I just can link them up. Was I supposed to install Reason to a specific area of my hard drive for PT to recognize it? Thanks for any help you can give. |
Re: Reason and Rewire problem
I'm having the same problem with Reason 2.5! I've posted my question elsewhere on this forum. I've also contacted tech support, if i hear back from them, i'll let you know.
Ross Rooney 2019 MB PRO 16" AVID CARBON, DOCK & S1. |
Hi, you'll need the latest version of Reason Adapted downloadable from here this will also install the latest Rewire bits,
OR just the Rewire can be found here if you want to use any other Rewire apps without installing Reason.
If I remember correctly from my installation, you will need to launch Reason once in "stand-alone", at which point the connection with PT is set up. I think that's also when you authorize your copy..
Make sure to get the latest version first, I think it is 3.0.5
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Just to check before i upgrade my reason.....it's the FULL reason 2.5 that i have NOT the adapted version. Do i still need to upgrade reason? Thanks for your help.
Hi, it's a bit unlikely to work with that version but if you already have 2.5 installed and it's not working it might be worth trying
the latest Rewire extention let us know if that works.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
Sorry but I completely missed the fact you were on an intel mac
o o o p s It's got to be the latest version of Reason (3.05) I'm afraid
No, i'm not on an intel Mac...it's a G5 quad 2.5 with 4.5 gig ram OS 10.6.8. PCI express. Digi OO2Rack. PT7.3 Do i still need to upgrade Reason? Thanks.
Ross here again. I'll try the rewire upgrade( 1.7 from the post above)this morning and let you know how i get on. Thanks.
Reason/Rewire problem in PT9 | rgfeaster | Pro Tools 10 | 3 | 12-30-2011 07:31 PM |
Reason 4 problem with ReWire | bdane | macOS | 0 | 10-14-2011 01:13 PM |
Problem with Reason, Rewire, and PT7.1 | StarSonicEnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-26-2006 08:52 AM |
Rewire with reason problem | LIl Face Prod. | Pro Tools M-Powered (Win) | 2 | 08-15-2006 11:38 AM |
Problem with Reason Rewire | Glenn75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-18-2004 09:06 PM |
