8.0.3 ASIO Drivers not working
Anyone else got a problem. I use Wavelab 6 and Cubase 4, neither of which seem to be working now, the ASIO drivers report no matching hardware.
Otherwise 8.0.3 is working fine for me on XP and Win 7 64-bit. Uninstalled 8.0.3 and went back to 8.0 and 8.0.1 and the ASIO drivers work just fine in oth of those versions. Last edited by lennieh; 01-04-2010 at 03:43 PM. Reason: more info |
Re: 8.0.3 ASIO Drivers not working
Same happens in Win 7 64-bit. If I go back to 8.0 or 8.0.1 the ASIO driver shows up in Wavelab and Cubase and works just fine.
Am I really the only person with this problem? I see over on the PTLE forum lots of folk had problems with the ASIO drivers in 8.0,maybe PTHD just caught up????? |
Are you making sure to disable your built in sound card, so that apps will default to using the Digi ASIO driver?
Yes, it's disabled in the BIOS.
Like I say the ASIO Drivers in 8.0 and 8.0.1 work just fine. If I install 8.0.3 I can see Digidesign ASIO Driver in the list of available drivers, along with the Eleven Rack ASIO driver. But if I select it I get a dialog box back saying something along the lines of "No matching hardware found on this system", same as I get if I select the Eleven Rack ASIO driver (this is obviously understandable because I don't have an Eleven Rack |
And here is my Sandra summary from the Win7 boot
SiSoftware Sandra Computer Model : empty empty Workgroup : WORKGROUP Host Name : DARC User : Lennie Processor Model : 2x Intel(R) Xeon(R) CPU E5420 @ 2.50GHz Speed : 2.5GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Tyan S5396 BIOS : Phoenix Technologies LTD 1.01I.5396 07/25/2008 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 2 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 16GB DDR2 FB-DIMM Chipset Model : Tyan 5400A Chipset Memory Controller Hub Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 16GB DDR2 FB-DIMM Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1D6 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1N8 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Memory Module : Micron 18HF25672FD667G1D6 2GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-18-5-3) Video System Video Adapter : ATI Radeon HD 4300/4500 Series (40 SM4.1 600MHz, 1GB DDR3 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4300/4500 Series (40 SM4.1 600MHz, 1GB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 1GB 400MHz) Storage Devices SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (F:) SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:) (D:) (L:) SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (E:) TSSTcorp DVD+/-RW TS-H653B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices Loops (F:) : 596GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) System (D:) : 54GB (NTFS) @ SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Audio (E:) : 596GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) System7 (C:) : 98GB (NTFS) @ SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Data (L:) : 147GB (NTFS) @ SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (G:) : N/A @ TSSTcorp DVD+/-RW TS-H653B (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Tyan 631xESB/6321ESB/3100 LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627EHF/EF/EHG/EG Audio Device : PC Partner R700 Audio Device [Radeon HD 4000 Series] Audio Codec : ATI (AMD) AA01h Disk Controller : Tyan 631xESB/6321ESB/3100 Ultra ATA Storage Controller Disk Controller : Tyan 631xESB/6321ESB/3100 Serial ATA Storage Controller USB Controller 1 : Tyan 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #1 USB Controller 2 : Tyan 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #2 USB Controller 3 : Tyan 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #3 USB Controller 4 : Tyan 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #4 USB Controller 5 : Tyan 631xESB/6321ESB/3100 Chipset USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Tyan TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 5X00/7X00 XMB Ch 21-0 SMBus SMBus/i2c Controller 2 : Intel 5X00/7X00 XMB Ch 21-1 SMBus SMBus/i2c Controller 3 : Intel 5X00/7X00 XMB Ch 21-0 SMBus SMBus/i2c Controller 4 : Intel 5X00/7X00 XMB Ch 21-1 SMBus SMBus/i2c Controller 5 : Intel 5X00/7X00 XMB Ch 22-0 SMBus SMBus/i2c Controller 6 : Intel 5X00/7X00 XMB Ch 22-1 SMBus SMBus/i2c Controller 7 : Intel 5X00/7X00 XMB Ch 22-0 SMBus SMBus/i2c Controller 8 : Intel 5X00/7X00 XMB Ch 22-1 SMBus SMBus/i2c Controller 9 : Intel 801xx/63xx SMBus SMBus/i2c Controller 10 : IPMI T1 Controller Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother MFC-660CN (600x600, Colour) Network Services Network Adapter : Intel(R) PRO/1000 EB Network Connection with I/O Acceleration #2 (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 |
I should probably say, I have a HD2 Accel PCI system.
DigiSpport Let me know if you want to see the Sandra report from my XP boot. But I get exactly the same behaviour on both, 8.0.1 drivers are good, 8.0.3 drivers don't see my cards... |
Try right-clicking on the app that you want to use ASIO with and choosing 'run as administrator' - let me know if it then sees the ASIO driver...
Wavelab is configured to run as Administrator in Win 7 anyway, it sees the ASIO driver, it just can't use it in XP or Win 7.
And the 8.0.3 drivers don't work in XP either! There is only a single Admin user on my XP installation so I can't run a program as anything else. I've also eliminated my I/O units (I have a 192 I/O and a Mytek 8x192), but even with these switched off, the 8.0.1 drivers function correctly i.e. if I select the Digidesign ASIO Driver I can get into the ASIO control panel. Whereas the 8.0.3 drivers report no compatible hardware. Can you just give me a kit with the 8.0.1 ASIO drivers to install over the 8.0.3 ones, so I get the best of both worlds, i.e. the fixes in 8.0.3 and ASIO drivers that work? |
I'm definately not going against digi tech, but I've never had to do this. Personally I've always left it on. Only time I have disabled it, I experienced problems.
https://www.thirdeyerecording.com/ |
Just installed PT HD803 on a W7 PC.
The System can not see the Digidesign hardware as output? Do I have to install additional Drivers ? Regards dl |
MBox 3 - ASIO Drivers not working | Accius08 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-07-2013 10:04 AM |
all right, what's with these ASIO drivers? | nonsqtr | Windows | 11 | 10-02-2011 02:03 PM |
ASIO drivers for XP | klg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2003 06:51 AM |
ASIO drivers for XP? What about for MAC? | beatboy | Pro Tools TDM Systems (Mac) | 15 | 11-22-2002 04:39 AM |
ASIO Drivers for PC | TimWay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-27-2000 11:07 AM |
