PT7 problems
Just checking if anyone else have experienced difficulties. After moving to 7.0 then 7.1 then 7.1 cs6, we have had the following problems after the 7.0 install:
- Reason crashes PT and itself on Plu-In launch - Waves plugs appear "faceless", plug window opens but no gui - PT occasionally goes into a loop, power-off only solution Anyone? |
Re: PT7 problems
Hi Justin,
I did have a couple of the issues you mentioned when opening fairly old sessions, or even some more recent ones. I traced it back to my VST Wrapper and some of the MIDI tracks. Solution was to create a new session and Import all the session Data. That seems to have fixed any hassles I had, and all new session have no glitches. Hope this helps, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
Re: PT7 problems
Set "Regional And Language Options" to US - OR 1. Select "Regional And Language Options" in controlpanel. 2. Click on the Custumize icon 3. Make the following changes: Decimal symbol: . (dot) Digit Grouping Symbol: , (Comma) List Seperator: , (Comma) Negative Number Format: -1.1 More: here
http://imaginatlh.com/91709 |
Re: PT7 problems
<PT occasionally goes into a loop, power-off only solution> That's the worst part. This happens when cpu load is near at half. I've also noticed that it's connected with graphic somehow, e.g. I can easily reprduce it when I have d2/d3 plugin window open and moving its knobs. The sessions were created with 7.1 I've tried all of those tricks like trashing preferences, reinstall PT, even tried different video card and memory sticks - no luck. I had no such problems with 6.9, I had different ones. Now they gone, new had come. I think its done specially for we would not be boring For Digi to note: All plugins are up to date. Live version 5.2. Asus p4c800e deluxe, 3.2ghz, 1.5gb memory, radeon 9600 256mb. All the best, Eugene |
Re: PT7 problems
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 11:04 AM |
Computer Problems vs Pro Tools Problems | mudlake slim | Pro Tools M-Powered (Win) | 1 | 07-14-2006 08:09 PM |
Rewinding Problems, Cutting & Pasting Problems | Nikki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2005 01:19 PM |
Problems, Problems, Problems all day long... | Jperkins | Pro Tools TDM Systems (Mac) | 5 | 05-12-2005 07:58 AM |
PC Probe problems. Any overheatingg problems with Digi 001 | Ajay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-03-2002 05:30 PM |
