Old 05-18-2005, 08:16 PM
reptilzar reptilzar is offline
Default Aah! Urgent help needed, 002R problem!!
Hi everyone, this just came out of left field on me.. I'm in the middle of a mix project, it needs to be done by Friday morning at the latest! I turned on my computer just now, it had been off for only a few hours, and the 002 Rack doesn't seem to be initializing right. It doesn't do it's little cycle of lights and clicks like normal, only the mute light is on right now and it doesn't respond. I haven't done ANYTHING new to this computer since I got it running, and it is an audio only PC. Here are the specs:
AMD 64, 939 socket, 1.8 GHZ
MSI K8V Neo system board
1 Gb DDR400 RAM
NVidia Geforce something or other cheap video card
TI Chipset Firewire card (has always worked perfectly with PT)
3x WD 80Gb 7200 drives
002 Rack
Any help is most appreciated, I'm in a bind!
r
Old 05-18-2005, 08:21 PM
albee1952 albee1952 is online now
Default Re: Aah! Urgent help needed, 002R problem!!
could be the power harness. remove the bottom cover and unplug-replug all the ribbon cable connections. or try another firewire cable as I have had one fail for no apparent reason.
Old 05-18-2005, 08:25 PM
I tried the firewire cables already, as well as using my laptop. no go. i will try the harness in a minute, what does it look like? Just a standard, IDE ribbon cable, or smaller, like a SATA?
Old 05-18-2005, 08:40 PM
if I remember right, its like an IDE ribbon except only 12-16 wires instead of 40. All the connectors are plastic or nylon. Its been 6 months since I reseated mine.
Urgent help needed! Movie export problem LE dru0013 Post - Surround - Video 11 10-20-2010 06:14 AM
Help needed - 002R stopped working - Clock problem ?! Gitareigandi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-02-2010 07:38 AM
Urgent help needed for clipping problem BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-14-2005 08:46 AM
Problem NOT solved! Urgent Help needed!!! mantaray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-15-2005 09:27 AM
Urgent help needed, 002R/Protools 6.1.2 problems! starlightmints 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-14-2004 07:53 PM
