Old 01-26-2014, 01:46 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Eleven Rack with a power amp setup
How are you guys pushing the eleven rack typically? (In a live setup)
Just in series in front of a guitar s
Amp? Via the fx loop? Or what kind of setup is most viable
Just curious of course - thanks
Daniel
Old 01-26-2014, 05:08 PM
Default Re: Eleven Rack with a power amp setup
I put the 11R in front of powered speakers (QSC). It works but honestly this is more an experimental system. Live I still either go through my Mesa Boogie Road King II into a Marshall 4x12 Cab or my Paul Reed Smith Combo amp.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 01-26-2014, 05:38 PM
Jay_uk Jay_uk is offline
Mission have announced at NAMM their new Gemini series.
check them out
http://missionengineering.com/?product_cat=geminiamps
Gemini H…..what they say:
Gemini with Mission EmPower™ Technology is the missing link in the world of digital modeling processors and software based guitar systems.
Old 01-26-2014, 07:12 PM
zedhed's Avatar
zedhed zedhed is offline
For me;
Main out to PA (FOH)...with a touch of foldback
Amp out to mesa boogie onstage.
I use two FX loops, the 11R & the mesa. The only FX on the Mesa loop is re-verb & delay. Using delay on the 11R FX loop in conjunction with delay on the mesa FX loop gives some interesting results.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 01-26-2014, 09:10 PM
gtrm8kr gtrm8kr is offline
Either to my powered studio monitors or to the effects return input on my Carvin Bel Air 2x12.
PT 12.3 on Win 8.1 Pro, i7-3930k, Sabertooth x79, 16GB G.Skill 2133, Lynx Hilo, Eleven Rack, a "few" guitars...
Old 01-26-2014, 09:15 PM
YYR123's Avatar
Good - I was thinking about using just the rack out to mains and monitors - instead of an amp - but idk most likely I can get away from the amp
Daniel
Old 01-27-2014, 04:50 PM
Effects return of my Marshall DSL401 (original not the new one) fed from the front panel amp output of the 11R.
Jack
QAPLA!
Old 01-27-2014, 07:27 PM
DonaldR DonaldR is offline
Depending of the gig I'm using one this 4 scenario:
1- XLR out to FOH and monitors (rig output and fx1 peq)
2- XLR out to FOH and Amp 1 out to Carvin 1x12" combo effect return (rig output and fx1 peq)
3- Amp 2 out to Peavey Classic 60/60 tube poweramp and Peavey 4x12" (rig output no cab)
4- XLR out to studio monitors (rig output and fx1 peq)
Old 01-28-2014, 09:17 AM
YYR123's Avatar
are you using this w/o the amp sim/ cabinet sim, just to get the sound of your marshall?
Just looking for a best way to set it up....Thanks guys.
Daniel
Old 01-28-2014, 11:20 AM
There's no best way, it all depends on your needs, your budget and your goal. I replied to you of the 4 scenarios I'm using depending of the situation. They all have their pros and cons.
Maybe if you give use a bit more detail about what you want to accomplish we can get better help you.
Eleven Rack Setup? philip888 Eleven Rack 6 07-05-2013 12:34 PM
Eleven Rack Power Plug Jemini Eleven Rack 8 11-10-2012 03:46 PM
Eleven Rack through Stereo Power Amp brewboy73 Eleven Rack 45 07-31-2012 04:35 PM
Eleven Rack Freeze At Power On 8-0 brianiac5150 Eleven Rack 3 11-05-2011 09:48 PM
Eleven Rack with Power Amp Volume killdozer Eleven Rack 7 02-19-2011 03:45 PM
