Old 09-11-2010, 11:49 AM
WernerF WernerF is offline
Default Quick HEAT question.
The manual says that HEAT launch's with pre as the default setting. The manual also states that HEAT is in pre when the "P" button is lit up. Every time that I launch HEAT the "P" button is not lit up. in other words the manual is contradicting itself. I have gone ahead and determined, by inserting a trim plugin on an audio track and observing it's affect on the HEAT meter on that track, that "P" being lit up means that it is in fact in pre. My question is; does HEAT launch with pre as the default setting for anyone else?
Old 09-11-2010, 12:40 PM
marrap's Avatar
marrap marrap is offline
Default Re: Quick HEAT question.
no. "PRE" is not lit up. that means default is POST.
if you see only a P expand your mix window setting.
wolfgang funk
marrakech prod
www.marrakechprod.com
www.linkedin.com/in/marrakechprod
https://pro-labs.imdb.com/name/nm3047395
Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX.
Old 09-11-2010, 01:14 PM
Hey marrap, thanks for the answer. I see all of the settings no problem. My confusion came from reading the contradictory manual. That'll teach me to RTFM. Ha
Old 09-12-2010, 12:12 AM
music music is offline
Agreed. I notice the same thing. You are spot on.
Old 09-12-2010, 08:24 AM
Could the writing of the manuals be being outsourced like the code writing is? Not very confidence inspiring.
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Question about HEAT and it's position in the chain. Metalgez Pro Tools TDM Systems (Mac) 1 03-09-2011 07:02 AM
Possible prefs question relating to Heat install bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 02:50 PM
HEAT question--is it pre or post on each track? bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 07:53 AM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
