Just learned another new, expensive lesson
Recently recorded some really great guitar tracks using a name brand guitar EFX processor stereo line outputs. The sound we heard while tracking was full, unique and incredibly easy to dial in so we were all excited about mixing these cool sounding guitars with the rest of the tracks and hearing some cool stuff. When it came time to final mix the guitars were not only kind of muddy but they seemed to detract from the other performances, specifically the bass and keyboards.
I spent months going back to this track while working on the other tracks, trying to get something that sounded anywhere NEAR what we heard in tracking. High pass, notching, verb, dynamics...whatever I could throw at this track I did...nothing did more than a minor improvement. Want to know what was killing this mix? It is so basic and unbelievable it is painful. I am still researching to see if their are known incompatibilities between digidesign and this gtr efx company because this should NEVER be the case when recording LINE outputs... The L and R of the stereo gtr efx were out of phase and canceling each other, mostly canceling out the highs and high mids of the stereo guitar tracks but also seemingly canceling out the other tracks frequencies in that range. Taking the punch out of the bass, all the edge off of the keys, dulling down my kick and snare...the whole thing is just incredible. I am still shaking my head about the simplicity of the problem. Last edited by Pred80r; 12-29-2009 at 10:41 AM. Reason: missed some words |
Re: Just learned another new, expensive lesson
i'm wondering if this was the new VOX guitar processor
supposedly ....."everybody's usin' it" i used it recently in "mono" mode that's how i got roped into to and away from using my marshall or my fender amps which i enjoying micing and moving some air the compression on this stuff is what carves itself into an unmanipulative state and as you said...sounds pretty cool when you are dialing in the sound and it's powerful sounding and different that "my" go to gear so i thought to myself..."change is good" huh not so sure i'm not to the mix stage but i do see how unmanipulative the tracks are you get kinda "stuck" and get work around with normal go to procedures.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
I'm a bit fuzzy on how the other elements in the mix were effected by the guitars being out of phase!! Chris
I always record straight DI guitar in addition to any other processing (including real amps). Bit late for you now I know......
Always, always, when tracking guitar or bass, track a mono track directly from the guitar's output through a DI in addition to your mics and processed line outs. Even if the line outs were not phased, you can still use this track to thicken up the sound by processing it with something else. So many guitar players tend to use settings that may sound cool to them, but simply don't work in the mix.
It's actually really funny when you play back a mix where you only used the processed DI track. The guitar player is usually like, "wow... how did I get such a cool sound out of my amp?" No need to tell them it wasn't their amp! |
When I track myself playing I usually don't even bother with mics and amps anymore. I've gotten very good at getting a better sound from a DI track.
The other trick is to make a few passes of the same part, and switch pickups on the guitar each time. Blending these together gets a nice fat sound. |
Always do it too. A lifesaver on many occasions.
Denis Mac Pro 3.3 hexacore 24 gb RAM Lion PT 10 HD Native |
Now that I figured it out however, the difference between the mixes is really night and day and fairly obvious to any ear...almost sounds like I know what I am doing as opposed to floundering in the muck. BTW the Guitar FX unit in question is a Pine 6 Lod |
My ADC issue fixed - a lesson learned | JimLeb | Pro Tools TDM Systems (Mac) | 3 | 11-17-2010 09:50 AM |
Lesson Learned: Ext Glyph/Mbox 2 Pro hum: Solved | GunnyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-12-2008 11:31 AM |
The all sm57 session. Lesson learned! | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 01-07-2006 10:59 PM |
A lesson learned from the pro's at DUC | randyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2005 09:21 AM |
What I learned about Drums! | toddamo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-02-2002 05:12 PM |
