DINR TDM (PT7.3cs1 - HD3 PCIe / Mac Pro)
I seem to have to be having a problem with the DINR TDM plugin, im only able to run one instance of the plugin on a session (mono, stereo or aux) that actually works. The first instance works correctly audio passes through and i can use the sliders and reduce the hiss that i need the plugin to do, but when I call a second or third instance on other tracks or aux, it loads up on the insert of the track, but there is total silence no audio passes at all, DINR doesnt detect any audio. Is this normal? I read the plugin guide and i found no mention of only a single instance. If any of you can test this and let me know if its just my setup, should i be loading DINR on a aux and using sends to bus each track i may require broadband reduction to it? Best Regards Craig Timmis |
Re: DINR TDM (PT7.3cs1 - HD3 PCIe / Mac Pro)
anyone? surely someone on 7.3.1 has this plug?
Thanks Craig Timmis |
After more testing, it appears that the DINR TDM plug doesn't work even on a previous working track if a session is closed and re-opened. I can sometime get it to work again by unloading it off a insert of the track and putting it back on. This is all very annoying, basically DINR TDM is unusable on PT 7.3.1cs1, just don't know what else to try, it just has to be major BUG problem with this, can someone please acknowledge the same behaviour, im going to submit a formal tech support request, as getting no answers here from any digidesign tech staff, Right in the middle of mixing a client track, got several noisy acoustic guitar takes i want to DINR in various ways ... thanks Craig Timmis |
Did you ever figure out what the deal with this was. I have only used the plugin a couple of times but remember some odd behavior like this in cs1. Now I am on 7.3.1cs5 and can't even get the plug to work at all as an insert on any track. It just comes up and does nothing. The audio on the track where it is inserted no longer plays. I have tried changing bussing, changing i/o, changing system settings, relaunching pro tools, restarting the computer. All that jazz. And the plug version is 7.3
Any resolution? |
I've had this problem too... Seems like the offline (AudioSuite) version works, but the TDM version is very unpredictable. The learn function especially seems flaky...
Cheers, eh? |
I don't want to be the "know-it-all" but are you still using DINR? I experienced much better results with more modern plug-ins from nearly every plug-in manufacturer who produces restoration plug-ins. DINR's technology is more than 10 years old and doesn't sound uptodate to me. As far as I remember there are two different processes DINR can be used for: -broadband noise reduction -hum removal The first can be a realtime process, the latter is AudioSuite only (if I remember correct) Kind regards Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
DAS |
no, I don't care. I tested the Waves Restoration Suite, Wave Arts Restoration Suite, TC Electronic Restoration Plugs and even cheap systems like one from Magix (Cleaning Lab Deluxe) bring much better results with less artifacts. I don't blame DINR. It was good when it was new because better solutions like NoNoise or Cedar were much more expensive. But ten years is a very long time in noise reduction technology and a lot changed. But sadly DINR didn't... Kind regards Mark
DeckLink HD Extreme II PCIe OR Intensity Pro PCIe? | MixerGuy | Pro Tools HDX & HD Native Systems (Mac) | 10 | 10-25-2012 10:15 AM |
Magma PE6R4 PCIe x4 plugging into Intel Mac PCIe x16 slot? | soloan | Pro Tools TDM Systems (Mac) | 2 | 04-27-2010 12:42 PM |
Anybody have Expressbox7 or Digidesign PCIe-PCIe chassis? | derF | Pro Tools TDM Systems (Mac) | 3 | 11-11-2008 05:08 AM |
can feat pcie hd accel to pcie x16 of motherboard? | raga2000 | Pro Tools TDM Systems (Win) | 6 | 06-29-2007 07:37 AM |
DINR - Sonic NoNOISE Special Offer for Registered DINR Owners | ProdInfo | General | 0 | 04-28-2003 11:31 AM |
